650L manual decomp
11 replies to this topic
  • CheGuevara
Posted March 17, 2005 - 03:44 PM
Can manual decomp be retrofitted to the XR650L? Would it be as simple as buying the assembly from an XR600 and popping it in?
  • pb1963
Posted March 17, 2005 - 04:21 PM
Why, you got e-start?
  • mgs781
Posted March 17, 2005 - 04:31 PM
Let me guess, aftermarket camshaft? Try it with just e-start first, you don't need decomp!
  • CheGuevara
Posted March 17, 2005 - 06:45 PM
Aftermarket cam, yes. I'm still building the motor, but I also have the 675 Wiseco kit (10.25:1 comression), so there is concern it may be difficult to start. The motor is in a TZ250 chassis, and as such I may need to use a smaller battery as well - I'm guessing anything I can do to make it easier to start will be a plus.
  • Chorbelt
Posted March 17, 2005 - 07:52 PM
that should make for a fun ride - pics?
  • CheGuevara
Posted March 18, 2005 - 09:48 AM
Ask and ye shall receive:
Posted Image Posted Image Posted Image Posted Image Posted Image Posted Image
It's actually a bit further along than the pics show - I just havent had a chance to take any more current (these are mostly as of Dec.).
So anybody know about the manual decomp? Lots of smart people on this board and I'm betting someone has my answer. :)
  • CheGuevara
Posted March 18, 2005 - 10:06 AM
If anyone's interested: The head was ported and rebuilt (new valves, springs etc) by Jay Wright of Barebones Machine (he actually said it required very little -mostly just cleaning up the ports), 675 Wiseco kit, rebuilt crank, every bearing in the motor has been replaced (believe me, that wasn't cheap!), will be running the Hotcams Stg 1 cam, carb to be determined but I may try an HSR Mikuni (42?) and the exhaust is yet to come but will consist of 1.5" primaries into a collector with about 2" outlet followed by a reverse-cone meg -no muffler (at least initially) so I'm sure my neighbors will love me.
I'm hoping I might get close to 50HP with that. Anyone know if that's realistic or am I smoking crack here?
  • CheGuevara
Posted March 21, 2005 - 11:17 AM
So 83 views so far and nobody knows if this can be done?
  • Shakeyhands
Posted March 21, 2005 - 05:32 PM
Did the Domi have a manual decomp? I'm thinking that it might be as simple, I would look at pre 95 DR 650's too, very similar and it has a decomp.
  • mgs781
Posted March 21, 2005 - 06:01 PM
I am almost positive that the XR600R head is the same as the L. The only difference between the two bikes is the stroke I think, besides e-start. Might be worth trying to get a used head off of e-bay and test fitting. The Ls head has all cast features of the decomp, they just didn't mahcine it.
  • mountainrider
Posted March 22, 2005 - 04:10 AM
You do not need it.I built my engine it cranks better now then it did when it was stock.If anything the decomp makes one harder to start.Without it when the engine comes up on the compression stroke it will fire right up.I have a Wiseco 10.25 piston,Hotcams stage one cam,Mikuni flat slide and we did a three angle valve job.I am happy with the bike and have had no problems with it starting.
  • CheGuevara
Posted March 22, 2005 - 11:30 AM
Thanks all for the info.
-Mike
  • 9 replies
Honda XR650L 2016
  • 0 reviews
  • 22 replies
Washington
  • Hot  32 replies
  • 4 replies
