Leaking coolant, but not from weep.
3 replies to this topic
  • Johnny34
Posted March 16, 2005 - 09:54 AM
I've done a few searches about this and found a lot of references to coolant leaking from the weep hole at the bottom of the water pump housing. I'm seeing coolant pooling and dripping from where the Y-pipe tube from the radiators connects to the top of the water pump housing. There is just one bolt that holds this y-pipe in place and an o-ring between the y-pipe and the housing.
I was going to drain the fluid and replace the o-ring unless any of you have other suggestions. Should I use some RTV high temp sealant as well? Should I pull off the water pump housing and replace that seal too?
FYI: This is an '05 WR450F with all the free mods and 75 miles on the odometer.
  • wakin
Posted March 16, 2005 - 10:12 AM
I had the same leak a few months ago. Indy helped me out, it's part #13
Sorry the link didn't go right there. Look up your bike, go to "Water Pump" - should be the O-ring (#13)
If I've confused you PM me
  • Indy_WR450
Posted March 16, 2005 - 01:26 PM
Yes and you may want to put a new o-ring and some silicone sealant around that pipe fiting above the o-ring. :) Glad that the fix helped you out as well Wakin. :)
  • mountainriderWR400F
Posted March 16, 2005 - 04:20 PM
I had the same problem quick fix no biggie local napa or dealer will have the o-ring and you probably all ready have a tube of silicon around don't you :) it is an annoying leak but a simple one nice job in tracking it down just think how much they would have laughed at the dealer :D knowing what was wrong and charging you a minimum shop fee of course. :) no big deal glad to hear that is all it was. :p
CAREFULL....8mm bolt and very easy to strip,
snug then 1/4 turn has always been good with me and then during your preride and your checking over everything just ad that in to your check list.
