Oil: synthetic or mineral?
2 replies to this topic
  • David_Reksten
Posted October 24, 2000 - 04:08 AM
Last time I changed the oil I used a fully synthetic Castrol motorcycle oil. Now the clutch sometimes slips when I'm hard on the throttle and the clutch is partially enganged.
A person I talked to said that he wished he had a nickel for each time he had to tell people that these bikes should be kept on mineral oil alone. He is something of an old-time cross legend here in Norway (currently races a YZ426) but his advice goes against pretty much everything I thought was true about mineral vs. synthetic oil.
Does his advice make sense, or has he just banged his skull into a rock one time too many?
What do you people use?
David Reksten, Oslo, Norway
2000 Yamaha WR400F
1998 Aprilia RS250
[This message has been edited by David Reksten (edited 10-24-2000).]
  • Andy_Baker
Posted October 28, 2000 - 06:35 AM
Hi , if it helps , I am using Putoline SYNTEC4+ and have done so since new. I have done nearly 2000km now , both on & off road and have no problem at all with clutch slip or anything else.
Andy
  • Guest_Guest_*
Posted October 28, 2000 - 06:42 AM
Hey David..... This subject has been discussed many times here, use the search feature and find them... also the archives.
