Yz426 Fork ?
6 replies to this topic
  • GMAN69
Posted March 15, 2005 - 04:22 PM
Well I dont know if I am getting old or what but after a muddy 4 days at hatfield mcoy I needed new pads on both ends. I took the forks off and did the steering bearings and then put them back on. The tire is still off with the bike on the stand while I wait for the parts to come in. Anyhow I noticed that one tube is about 1" lower (or higher) than the other. There set the same up top and I know when I put the tire back on I can push them back even but should they be like this? No seal leaks either.
  • Matt96xr6
Posted March 15, 2005 - 07:39 PM
that is not right.
Most likely the rod has broke or come unscrewed from the cap. Inspect immediately!
Other things that could be wrong are you have a bent tube, missing the lock ring for the seal causing the inner tube to seperate from the inner or you have worn fork bushings.
  • elburro
Posted March 15, 2005 - 07:42 PM
I know mine is not this way, or any other bike i've had. Make sure you push in the air valve at the top, to make sure there's no pressure . If thats not it then probably fluid levels are off. Replace with correct amount of fluid.
  • mxmark410
Posted March 18, 2005 - 03:20 PM
Gman, I think you have serious issues and should consult a reputable Honda Dealer as soon as possible. Remove the fluids from your current bike and put in the backyard on a stand and let the kids play on it like an old swing set.
  • ncmountainman
Posted March 18, 2005 - 03:46 PM
so who's gonna organize the lynch mob ??? :)
  • GMAN69
Posted March 18, 2005 - 04:43 PM
Its unfortunate that even with the issues with the blue monster it spanked the hell out of that new honda of yours. Maybe if you bore it out to a 500 and loose 50 pounds off your fat a$$ you could keep up on the trail.
  • sanpedro426
Posted March 18, 2005 - 05:09 PM
Theres nothin like good ole TRASH TALKIN. YOU GO BOYS. :) :)
