larger tank for '04
4 replies to this topic
  • woodsk
Posted March 14, 2005 - 09:08 AM
I'm going to be getting my 450 plated and selling my already plated 400. Before I l let the 400 go I want to get the 450 set up for some long hauls. I have the carke 3.3 tank on the 400 which gives a me a nice range but I belive (and it could just be in my head) that it is contributing to some of the top heavy feel. So before I put the same tank on my 450 I wanted some of your thoughts on the other tanks. IMS, acerbis, maier anyone have one they really like on an '04
  • Endurordr
Posted March 29, 2005 - 10:14 PM
I'm looking for some info as well for my '04. Looking at the IMS 3.0, and whatever else is out there. I'm not looking for the biggest, just for something a little more then stock.
  • jim-in-so-ore
Posted March 30, 2005 - 06:37 AM
Just for your information, Clarke only makes a 2.8 gallon tank for the 03, 04 & 05 WRs. That is just 2 tenths of a gallon more than stock, not worth $175.00 for that small amount IMO.
IMS is said not to drain all the way because of the design, plus the right side petcock is only a gnats eyebrow from the header pipe. It is 3.1 gallons.
The Acerbis/GYT-R tank is 3.3 gallons and has a decent gap between the right side petcock and the header pipe but sits taller so it has a slightly top heavy feel. With the 03 & 04 you will need YZ shrouds on any of the after market tanks. I understand on the 05s you can use WR shrouds also. :naughty:
Jim
  • dez4ever
Posted March 30, 2005 - 11:57 AM
I have the 3.1 IMS on my WR and the right petcock rubs against the head pretty good. It also rubbed on the left side just not as bad. I never got it down low enough to see if it would utilize the fuel on the lower right side of the tank. I have since taken it off mainly because of the rubbing problem. The overall feel was pretty good, it definitely kept the weight low but it did feel a little wider than the stock setup, but not much.
  • black_n_blue_thumper
Posted March 30, 2005 - 09:56 PM
Does anyone besides Clarke make a black tank? :naughty:
