breaking in my new bike
6 replies to this topic
  • Decepticon
Posted March 12, 2005 - 06:28 PM
Hey guys
just wondering if any one knew of the best way to break in a new 05 wr450f - as i can tell its a pretty controversial subject, however i'm really hoping some one knows.
thnx - yours in thumpering
Ceps
  • Domenic_WRF
Posted March 12, 2005 - 06:46 PM
Change the oil and filter first :) then ride it like you stole it.. :p then change the oil again.. :) change it at least twice in the first 50 miles..Enjoy :D
  • Decepticon
Posted March 12, 2005 - 06:49 PM
ok awesome thanks heaps - also can any one tell me some mods i can perform on an aussie standard wr - already put new DEP pipe and vortex ignition on (dam i love that ignition first tim start) had a look through the mods page but all seem to be american issue wr mods.
wat about us lil guys down under ey.
cheers
ceps
  • Dan_from_HB
Posted March 13, 2005 - 11:58 AM
I'm not a fan of breaking in a new motor by "riding it like you stole it". IMHO, that's a cult myth that sprung up from some engine rebuilders that paid a little too much attention to factory race mechanics at supercross races. Unless you know exactly what tolerances work with that type of break-in, and unless you have the budget to rebuild your top end every race, I'd take it a little easy on that motor for the first few tankfuls.
  • Sylvain
Posted March 15, 2005 - 02:34 PM
IMHO
Re-grease all the bearings.
Do not over rev or bog down the engine.
Do not keep the engine at constant rpm.
The first rides should allow the engines to reach normal operating temperature at different rpm under variable loads.
Change oil and filter at 100 km / 200 km / and after what interval you decide to go from the shop manual.
The shop manual as good info.
The rest is up to you :) enjoy
  • beezer
Posted March 15, 2005 - 02:42 PM
I check nuts and bolts, fluid levels. I ride around for 2 minutes and change the oil and filter.
Its broken in.
Life is to short to ride around like a girl for 2 hours.
  • bottomfeeder2
Posted March 15, 2005 - 03:44 PM
Its broken in.
Definitely take a few minutes to check bolts for tightness. I've owned two new WRs (an '04 that dealer swore would be green stickered and an '05 with a green sticker). Both of them had something fall off within the first few tanks. On the '04, the pipe insert fell off (not the end of the world). On the '05, one of the bolts holding on the front number plate fell off. You'd think I'd have learned to check everything after the first time.
