AC volts coming from the brake light
13 replies to this topic
  • Supermoto XR600r
Posted March 12, 2005 - 12:39 PM
Anybody got any idea why I'm getting a AC power going to the back light and not DC
I replaced the Slater and ever since I'm getting a AC power to the back light, the front light are working but not the back
Plus the green and white with yellow strip coming from the AC reg and getting very hot?
Have took out all the wiring to check and it all seems fine not earthing anywhere I can see
Plus i forgot to say the horn is not working either
Anybody got any ideas?
  • Chas_M
Posted March 12, 2005 - 03:42 PM
I don't know about XRs, but with KTMs AC powers both the headlight and taillight on the stock enduro models.
  • xlerate
Posted March 12, 2005 - 06:35 PM
i think the same thing. my 85 xl600 head light and tail light both run off a/c. i recently replaced a/c regulator, was blowing bulbs.
  • XR250rdr
Posted March 12, 2005 - 09:07 PM
If the stock regulator is on the bike then both lights are running on AC.
  • Supermoto XR600r
Posted March 15, 2005 - 05:54 AM
This has me puzzled, should I be getting AC volts coming from the head light and tail light? or should i be getting DC volts
anybody got any ideas
  • roosterk0031
Posted March 15, 2005 - 07:31 AM
XR'r's only use ac current. A rectifier is used to convert a/c to d/c to charge a battery, but since xr'r don't have a battery there was no need to add the rectifier. The regulator contols the voltage level holding it to a constant 14 volts (guessing) regardless of engine rpm. Stators make alternating current. XL's need a rectifier to charge the battery. I don't know what else on XL's use dc or ac current. David
  • XR250rdr
Posted March 15, 2005 - 01:37 PM
XLs dont have a split supply like KTMs do. The entire output of the stator is rectified to DC. The XRs simply have an AC regulator and 14V sounds about right.
KTMs have a coil that is regulated AC for the lights and another that is rectified to DC to charge the battery.
  • rmhrc630
Posted March 15, 2005 - 03:44 PM
Ah but in australia all XRs have DC power as well as AC power. AC rightly powers the lights and AC power is what comes out of the motor. DC power fuels your horn etc.
BTW XRs in australia do NOT have batteries - we have our bikes homologated for the road off the showroom. DC is needed to power the horn and blinkers in particular. The lights can be run off AC power but you still need a regulator.
US model XRs have no DC regulator so their wiring harness is smaller and lighter than ours. In the US though when you convert for road use, you have a crazy law that requires a battery be fitted (presuambly to power a break light???) so that requires DC power.
I think you're mis plugged something. AC power is pretty simple.
  • Supermoto XR600r
Posted March 15, 2005 - 04:05 PM
God wish you where on my side of the world, bought it to a bike shop and they were talking like they had there heads up there arse, they haven't got a clue
anyway here's to another day of messing around with wires, good thing i've a few days off work
  • don87xr600
Posted March 15, 2005 - 05:10 PM
The battery is to run the taillight for 15 minutes after the bike is shut off.
  • bork
Posted March 16, 2005 - 09:40 PM
Funny you guys should mention this . LOL I spent a bunch of time making a little adapter to plug in to stock xr600r rear bulb holder for the usual 1157 bulb which I now know doesn't work ( ac I guess , right? ) Any ways I went back to the 904 bulb. Burns bright , but I use a resister under seat to cut down power so it looks like a running light then the presure-switches from front and rear tie back into sytem down stream from resister as to give full power and thus bright brake . BTW I put a double contact in front assy to accept a bulb from a banshee quad .( much more available and cheaper ) Also nice for back up in case of burn out , I can just replug in other hi/lo filement. :)
  • Chas_M
Posted March 17, 2005 - 12:17 PM
Thats kind of strange about the 1157 bulb not working with AC. In my bike, AC runs a 1157 bulb just fine!
  • roosterk0031
Posted March 17, 2005 - 01:05 PM
Light bulbs don't care if ac or dc current, all they need is voltage.
  • bork
Posted March 17, 2005 - 07:43 PM
Thats wierd . After it didn't work on bike, I took out and tried on car battery & worked fine . I put 904 bulb in bike and it now works fine . But not the 1157 ? Good way to make a blonde dizzier ! You guys with the 1157 have a dual sport kit? :)
