Change sprocket bolts ?
12 replies to this topic
  • Fryboy
Posted March 11, 2005 - 08:42 AM
Hi everyone,
I am currently replacing my drive train. While tightening on my rear sprocket one of the bolts broke. My question is, would you replace all the bolts or just the one that broke? My concern is if one broke perhaps some of the others are ready to any time? Being so cheap the price isn't a concern. What would you do?
Thanks
Fryboy
  • scotty38
Posted March 11, 2005 - 08:49 AM
I think that's your answer, replace them.... :-)
  • kevin1209
Posted March 11, 2005 - 09:00 AM
Did you use a torque wrench? You just overtightened it, that's all. If you want to spend the money, replace them. But a bolt doesn't lose its strength unless you actively overstress it. I'd save the money for other stuff. :)
  • mtrablue
Posted March 11, 2005 - 10:51 AM
replace replace replace. there have been enough guys on this forum that have wasted rear hubs from busted sproket bolts to get my attention. there's an outfit that sells a kit on ebay. a couple buddies are using these nuts and bolts and are very pleased with them.
  • msgbean
Posted March 11, 2005 - 01:56 PM
Don't take any chances. They are only $12 at www.motorsportsoutlet.com.
  • Fryboy
Posted March 11, 2005 - 02:01 PM
Nope didn't use a torch wrench. And I wasn't overly tightening the bolt as far as i could tell :p
I have made up my mind, I am switching out all of them. Thanks everyone for helping me make up my mind :)
Fryboy :)
  • CISCO
Posted March 11, 2005 - 03:40 PM
Nope didn't use a torch wrench. And I wasn't overly tightening the bolt as far as i could tell :)
Fryboy :p
Replace them dude. Look at my sprocket luck and dont think twice. Replace them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Sylvain
Posted March 11, 2005 - 04:32 PM
Replace the bolts and nuts, use a torque wrench and apply blue loctite (removable). :)
  • Gadsen
Posted March 11, 2005 - 04:48 PM
Hi everyone,
Thanks
Fryboy
If one broke, then others migh later, under heavy load, then it could tear up lots more. Replace them all now.
  • drewpeacock
Posted March 11, 2005 - 06:39 PM
I too tried the cheap route once and it cost me a rear hub, engine case and a thirty mile ride back on my wifes bike, with her on the back. :)
  • Tab812
Posted March 11, 2005 - 08:55 PM
I second, Replace,Replace,Replace.....
  • Indy_WR450
Posted March 14, 2005 - 04:27 AM
I always replace them with every new rear sprocket. Bolts are cheap. Hubs are expensive! :)
  • MathProf
Posted March 14, 2005 - 05:24 AM
Replace them.
You need to be VERY CAREFUL about your chain tension. It is easy to make the chain too tight and that will pull on the rear sprocket and pop a bolt or two.
Were any other bolts loose or was it just the one???? :)
