JD Jetting Instructions
1 reply to this topic
  • clark4131
Posted March 10, 2005 - 06:06 PM
I lost my instruction sheet and was wondering if anyone could send me a copy via email. I'll name my next kid after you if you can help me out :) . Muchas Gracias...SC
  • Indy_WR450
Posted March 10, 2005 - 08:12 PM
JD instructions are a little on the rich side from my experience. Try this:
Elevation 0 to 4,000. feet
30 to 45 degrees: 172 main, JD Blue #5, 48 Pilot, 2.0 turns, 75 starter jet, #0 leak jet
45 to 60 degrees: 170 main, JD Blue #4, 48 Pilot, 1.75 turns, 72 starter jet, #0 leak jet
60 to 75 degrees: 168 main, JD Blue #3 or JD Red #5, 48 Pilot, 1.5 turns, 70 starter jet, #40 leak jet
75 to 90 degrees: 165 main, JD Red #5, 48 Pilot, 1.25 turns, 68 starter jet, #50 leak jet
90 degrees plus: 160 main, JD Red #4, 45 Pilot, 2.0 turns, 65 starter jet, #60 leak jet
Elevation 4,000 to 8,000 feet:
30 to 45 degrees: 170 main, JD Blue #4, 48 Pilot, 1.75 turns, 72 starter jet, #0 leak jet
45 to 60 degrees: 168 main, JD Blue #3, 48 Pilot, 1.5 turns, 70 starter jet, #40 leak jet
60 to 75 degrees: 165 main, JD Red #5, 48 Pilot, 1.25 turns, 68 starter jet, #40 leak jet
75 to 90 degrees: 165 main, JD Red #5, 45 Pilot, 2.0 turns, 65 starter jet, #50 leak jet
90 degrees plus: 160 main, JD Red #4, 45 Pilot, 1.75 turns, 65 starter jet, #60 leak jet
Elevation 8,000 to 11,000 feet: ( Note you will loose a lot of power due to altitude but your bike will idle and not foul plugs!)
45 to 60 degrees: 165 main, JD Red #5, 48 Pilot, 1.25 turns, 70 starter jet, #40 leak jet
60 to 75 degrees: 160 main, JD Red #4 , 45 Pilot, 1.75 turns, 68 starter jet, #50 leak jet
75 to 90 degrees: 158 main, JD Red #3, 45 Pilot, 1.5 turns, 65 starter jet, #60 leak jet
