98wr400
2 replies to this topic
  • Tiny
Posted March 09, 2005 - 04:45 PM
I just bought this bike used. I am looking for the oil filter/screen access. By the best I can tell, it is on the right side above the coolant pump. Can anyone confirm this? It also looks like the exhaust needs the be moved to remove the panel or access the upper bolt. Can Anyone please confirm?
Thanks,
Tiny
  • HGuthery
Posted March 09, 2005 - 07:03 PM
Just loosen the exhaust and move it out of the way. You might also want to remove the line at the bottom of the frame downtube and check the screen behind it. Good luck!!
  • mountainriderWR400F
Posted March 09, 2005 - 08:29 PM
Thanks,
Tiny
Try this website should have what you need and also check on the top for other options good site hope this helps. :)
http://www.thumperfa.../oil_change.htm
