Crankcase pressure?
8 replies to this topic
  • tullymars
Posted March 08, 2005 - 05:14 AM
How do I determine that I have to much crankcase pressure on my 650L ?When the bike is idleing,it has a strong pulse of air coming through the breather hose.
  • XR650L_Dave
Posted March 08, 2005 - 09:00 AM
That strong pulse of air is caused by the piston moving down in the cylinder bore- just about 650cc worth of air! At higher revs, the piston moves down and back up faster than the air can leave via that little hose, so the pulses smooth out a bit.
Dave
  • tullymars
Posted March 09, 2005 - 10:28 AM
I understand what it is,but is it to much,is it blowbye?
  • Ron_Meidlinger
Posted March 09, 2005 - 10:52 AM
is it smoking out the breather
  • tullymars
Posted March 09, 2005 - 11:13 AM
No,not smoking
  • rmhrc630
Posted March 09, 2005 - 03:49 PM
Its normal mate.
Leave it alone and ride
if it wasnt there - you would blow you cases apart on the first creek crossing
  • tullymars
Posted March 09, 2005 - 05:16 PM
Its normal mate.
I know its normal,but what I'm asking is how much is to much?
  • XR650L_Dave
Posted March 10, 2005 - 08:12 AM
If you're not getting a bunch of smoke or a lot of oil, its normal.
If it goes beyond normal, the combustion gases leaking past the rings will cause a lot of smoke, probably cause the bike to overheat, and will carry a lot of oil out the breather.
Dave
  • crwmac
Posted March 11, 2005 - 09:43 AM
You would be amazed at how much technical information there is on the web about crankcase pressure, especially for racing applications. However, your question has a fairly simple answer. The piston going up and down causes the pulses that you feel. If it weren’t for blow-by, a breather wouldn't be necessary. However, because blow-by does occur, more or less depending on how good your rings are, pressure would rapidly increase in the crankcase if there were not a breather hole. It would increase to the point where oil would be pushed past any weak points in the engine and you would have really bad oil leaks. On the XR650L, the breather outlet is 1/2 inch but is reduced at the "T" fitting to 3/8 inch. I am sure that this breather size is designed by Honda engineers to allow for the correct crankcase pressure, which is probably atmospheric pressure plus or minus (thus the pulses). To find out precisely, you would have to find a device that could be put in the crankcase to measure pressure while the engine is running and have some engineering data from Honda to compare the results to. The bottom line is, pulses are a good thing. Not to worry.
Hey, I am no expert; I have been reading a lot lately on the same question.
Mac
  • Hot  29 replies
  • 4 replies
  • Hot  186 replies
  • 17 replies
Honda XR650L 2016
  • 0 reviews
