05 Gearing
13 replies to this topic
  • mmbasa
Posted March 07, 2005 - 08:36 PM
Thinking about changing the gearing on my 05 450. What are you guys running for the track? Stock just isn't feeling right.
  • Ga426owner
Posted March 08, 2005 - 11:14 AM
05 is 50 or 51 right? :)
What does not feel right?
  • SLO_Rider
Posted March 08, 2005 - 11:25 AM
I went from a 51 to a 50 tooth on my '05 450 and like it very much. I felt that the 51 was dropping off a little too soon at top speed. The 50 matches my track and riding style just right :)
  • mmbasa
Posted March 08, 2005 - 11:50 AM
Thats I'm thinking, it drops off just a bit on the top end. How much did you lose on the bottom say in 2nd gear?
Posted March 08, 2005 - 12:19 PM
I run 15/48, same as 14/46. What's stock on the '05?
  • rmracer27
Posted March 08, 2005 - 12:33 PM
Stock on 05 is 14 front and 51 rear..
  • SLO_Rider
Posted March 08, 2005 - 03:22 PM
2nd gear didn't lose very much bottom at all, it will just rev out farther. Last weekend I was starting in 2nd gear and got the hole shot both motos :)
Posted March 08, 2005 - 04:21 PM
Dang, no wonder top end falls off. That's 250F gearing. '03/'04 was 14/48, and that was too low.
  • rmracer27
Posted March 08, 2005 - 04:49 PM
Yeah I know thats what the 03/04's run and I have been trying to figure out what way I want to go. I know the top falls off real quick on 05.
  • mikedabike
Posted March 08, 2005 - 05:58 PM
The 03 and 04 use 14/48 the 05 uses 14/51 but has different internal ratios. The final gearing is almost identical.
  • ThumperKid250F
Posted March 08, 2005 - 06:11 PM
just a thought and im prop, wrong. but do you think this is why people are saying the 05 is slower.
  • Joe_Jet
Posted March 08, 2005 - 08:12 PM
I understand that was done to keep the tranny and clutch spinning faster to allow softer clutch springs for a lighter lever pull.
  • rynno716
Posted March 08, 2005 - 10:40 PM
I run mostly motocross and 14/45 works good for me. your riding style may vary.
  • motomike137
Posted March 09, 2005 - 08:48 AM
This whole subject revolves around a couple of variables. First off for those who don't understand the 05 has a taller ratio number at the drive sprocket thus needing the larger rear sprocket to bring it back to near the 03/04 final gearing. On 03/04's a lot of guys tamed the bike down by going with a smaller rear sprocket. This makes the gearing a little taller and spreads the gaps between the gears just a little. Most guys were looking to utilize second gear with an occasional shift into third. For me personally I found it more to my liking to do just the opposite. I went a couple teeth up on the rear and ran third most of the time. I used second to get over the gate grabbed third and pretty much left it there. This set up also made 4th a little closer to third and more useable when i was on a long enough straight to grab another gear. I am assuming I'm going to do the same with my 05. It all comes down to rider preference and feel. Don't be afraid to experiment with the gearing a little bit. Just think about what the bike feels like and what you want to change about it and give it a try.
