400 throttle kinking/fraying
5 replies to this topic
  • TallBoysWRF
Posted March 07, 2005 - 05:19 PM
I have noticed my throttle sticking, and when I went to lube the cables up, I noticed that about an inch or so from the carb the pull cable has a bit of a kink in it and at the kink, the cable has started to fray. I have been searching around and can't find much about the cause of this. Any ideas?? I can't figure how the kink got there bacause everything seems to line up between the wheel and the cable bracket :)
  • Indy_WR450
Posted March 07, 2005 - 05:21 PM
Time to replace it! After all it is a WR400! :)
  • TallBoysWRF
Posted March 07, 2005 - 05:35 PM
I'm going to, but I also want to fix the cause.
  • mountainriderWR400F
Posted March 07, 2005 - 06:24 PM
Ouch Indy :) that hurt I have a 99 wr400 and it rips :) hey at least it is a wr!
  • Indy_WR450
Posted March 07, 2005 - 07:36 PM
Now dont misunderstand. :) What I meant was the age since it was a WR400 the throttle cable may even be 5 years old! :)
  • 5valve
Posted March 08, 2005 - 07:39 AM
had the same problem (tearing near the wheel); 4 years is a long time for throttle cable life, moving up&down most of time unlubed
luckily there are people renewing those cables..if outer shell is undamaged, just replace the inner cable and voila
