Where to get inexpensive 426 oil filters?
15 replies to this topic
  • NuckingFuts
Posted March 07, 2005 - 01:50 PM
The dealer here wants $10/oil filter!!! NO WAY. Wondering if you guys know where to get WR426 oil filters for SIGNIFICANTLY cheaper? :)
  • doctorchopper
Posted March 07, 2005 - 02:22 PM
You can get them on ebay for really cheap, get the metal ones then you can clean them, they cost a little more, but you will save in the long run
  • TallBoysWRF
Posted March 07, 2005 - 05:24 PM
Try the scotts unit. It is like $99 :)
  • toyota_mdt_tech
Posted March 07, 2005 - 06:42 PM
I second the ebay one. Just type in WR in the search bar and you will find a guy selling packs of 5 for about $23! Just make sure its for the 400/426, as the 450 filter is a little different. I bought a 5 pack from him when I had my 426 also, bought another batch for my 450. The earleir 400/426 filters are a little bit more $ than the 450, but still a killer deal compared to what your spending now.
  • ncmountainman
Posted March 07, 2005 - 06:49 PM
i just ordered one from the TT store,it was only $63. i've been using the screen type from the 426's but they just don't filter as well as the scotts and i also believe the paper ones offer a little too much flow resistance,especially if a little water gets in your oil then its all blown right thru the bypass (no filtration) :)
  • TallBoysWRF
Posted March 07, 2005 - 06:59 PM
OK, I take that back, the Scotts site says $69.95, that is still a crapload of $ for a filter.
  • NuckingFuts
Posted March 07, 2005 - 07:02 PM
Thanks for the ebay lead fellas........I'll give it a shot! :)
  • mmbasa
Posted March 07, 2005 - 08:39 PM
Cycle Gear $3.99, just look for the HiFlo in the green boxes. Lots of dealers carry them.
  • BubZ
Posted March 08, 2005 - 08:27 AM
Mountain Man, I treid to find the Scotts oil filters at the TT store and their search engine said it couldn't find them.
Could you tell me where to look and what the part number is?
Thanks,
Bud
  • ncmountainman
Posted March 08, 2005 - 08:28 AM
call them,thats how i did it. they said nothing of availability issues :)
  • Cedric
Posted March 08, 2005 - 09:45 AM
I don't know if this might help you out, but I found out that my Dad's Warrior ATV takes the same filter as my WR 400. Might be worth a look in your quest for cheap filters. I buy the $10 metal ones, but I usually clean them out instead of replacing them, so long as the screen is still in good condition.
  • Seabass
Posted March 08, 2005 - 04:52 PM
The Yamaha filters are going for over $11 at my Yamaha dealer. I change my filter every other trip out. $70 is cheap over the long run
  • 642MX
Posted March 08, 2005 - 05:46 PM
I use the K&N 142 filter, its metal and seems to filter just fine. I've cleaned it and used it for a year now and its held up fine (so has my motor). And the best part it sells for $9.95.
  • TallBoysWRF
Posted March 08, 2005 - 06:22 PM
Exactly! If you clean the filter $10 is not a bad price. If you change the filter every oil change, then $10 is a lot and $70 is not so bad. :)
  • 642MX
Posted March 08, 2005 - 07:36 PM
No man I think you read that wrong. I clean and reuse my $10 oil filter.
  • TallBoysWRF
Posted March 08, 2005 - 08:27 PM
No, I am agreeing with you, read my post again... I'm saying that $10 (1x) for a lot of oil changes is cheap, but $10 for every oil change is a lot of cash, hence the $70 would be cheaper after 8 oil changes. :)
