Carb sincro on 87 600r
3 replies to this topic
  • 87XR600R
Posted March 05, 2005 - 09:34 PM
Hello guys, I am new to this forum and new to the thumper bikes. I have a question about the carbs adjustment on my 87, When I pulled the air box off the pistons in the carbs are not at the same height. Are they set up to be progressive? John
  • XR6's_rule
Posted March 06, 2005 - 01:45 AM
With the throttle closed, both slides should be right down or fully closed. When you open the throttle, the left or primary carb will open on its own for the first 1/8 or so of the throttle travel, then a linkage and lever opens the secondary carb. There is meant to be a specified amount of opening clearance for the primary to secondary carb linkage (or secondary touch lever) it is 4.5-5.0mm.
Hope this helps!
Mark.
  • StevePSD
Posted March 06, 2005 - 07:21 PM
The primary carb (the left one) has a cutaway on the bottom of the slide, that the secondary carb does not. It might appear that the left slide is sitting higher due to this.
  • 87XR600R
Posted March 06, 2005 - 09:18 PM
Thanks guys, I appreciate it. John
  • 17 replies
  • 4 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2016
  • 0 reviews
