need advice fellow TTer's
8 replies to this topic
  • mayday
Posted March 05, 2005 - 07:30 PM
Hey I Dropped a valve in my 02 426 and the motor is trashed. I just dropped 5 bens on new chain sprockets,clutch plates, wiesco piston etc. What would you do find a 02 426 or a new 450 and why? I figured an 02 426 so I can swap my scott's dampner and triple clamp and all my new goodies. :) :)
  • smokin529
Posted March 05, 2005 - 07:53 PM
Why can't you re-build your motor? If the cylinder is trashed, Eric Gorr has exchange cylinders w/piston kits for a reasonable price. Your triple clamp won't work on a '04 450 because the fork tubes are bigger.
  • mayday
Posted March 05, 2005 - 08:05 PM
when the valve dropped it messed up my head and cylinder
  • John_Lorenz
Posted March 05, 2005 - 08:34 PM
That depends on what you wish to do, MX or woods and how goo dyou are
I mean the later in a plain way.
Will you benifit form going to a 450?
or are you as fast on the 426?
personally I like the 426, the 450 is nice, but
  • cowboyona426
Posted March 07, 2005 - 12:12 PM
I would rebuilt it if it were mine. The parts will be expensive, but not as much as a new bike and it will be just as fun.
Posted March 07, 2005 - 12:55 PM
Plan A would be to try to find another cylinder head on E-Bay or elsewhere (This guy might have one ), and rebuild it. A whole new cylinder costs less than most bore and replate jobs. But, you should have the crank redone, too, since the impact of chewing on the valve may have slammed a few dents in the big end.
Other options would be to buy another '02, or an '03 450 (a lot of your stuff will fit, including your clamp), or a newer one.
Tough decision.
  • Indy_WR450
Posted March 07, 2005 - 01:44 PM
You are better off rebuilding her and getting another 3 - 4 years out of her. Drop $2,000 - $2,500 in her and rebuild her right!
new clutch baskets
new countershaft bearing and seals
new water pump shaft and seals
new crank ( cam chain sprocket wears and hooks)
new cam chain and tensioner
new engine gasket kit
new jug
new piston (make her a 450) & rod
replace the valves, springs and guides and get a port job on the head.
It will run as good as a new 450 and it will end up costing you less in the long run! :)
  • mayday
Posted March 07, 2005 - 02:47 PM
thanks all I found a 02 426 that is in awsome shape barely riden for about the same amount to rebuild mine. So that is the way I am going. But I will keep a look out for parts and put it back together with time. Then I will have 2-02 426 to ride. I need a bike soon I got a race this Sat. Thanks fellow TTer's for your inputs :)
  • MXof21
Posted March 07, 2005 - 02:49 PM
I had great luck parting out a 2002 YZ250F when my engine blew. I saved what I could and sold the rest off as a partial payment on a 2003 YZ450F. I just listed everything here on TT and sold just about all of it for the price I asked, I think I asked about 25% of the replacement cost.
