Will a heavy flywheel help in the sand?
11 replies to this topic
  • noslo98
Posted March 04, 2005 - 12:38 PM
I know the two stroke guys are running heavier flywheels when you go to the dunes but will it help on a four stroke on hills? im thinking it will but who knows? basicly what im trying to do is be able to race people up the main hill where i go and be able to do it in fourth gear currently i do but it kinda lugs at the top so it doesnt matter if i am in third or fourth. According to the radar gun it was 48mph in fourth and 47mph in third at the top . Im thinking the wieght should help me carry the momentum all the way up the hill. I am running an 03 450 with 13/48 gearing i could go down more in gearing but then i will just loose mor top end right.I am trying to smoke 2 smoke 500's currently i pull on them but thats not enough for my satisfaction.
  • YZ426FPilot
Posted March 04, 2005 - 03:32 PM
The only way to go faster in the sand is to add more ponies... Play with gearing, fuel, cams, bump up the cc's etc... Or just go buy yourself a KTM550 throw a 12 paddle on and rock that b!tch in the dunes!
  • noslo98
Posted March 04, 2005 - 03:53 PM
I was thinking of more gearing like going from 13/48 to 13/49 because i dont want to kill too much of my top end. that way i could still get away with throwing the 14 back on for track riding. and the 13/49 would just tear up the hill or better yet 13/52 then i have to fight the front end but it would be wild for the first 60 ft or so.
  • Shorte01
Posted March 04, 2005 - 04:28 PM
I'm in the sand a lot and run 13/51, first time out after putting the 51 on I noticed a big difference, yeah you lose the top end but when you're going up a hill top end doesn't mean much if you can get there.
  • 99wr400
Posted March 04, 2005 - 04:49 PM
I use 13-52 gearing all the time, and I have a WR400 the only time i need higher gears is in an open strait road. My bike will still do 65 easily. have your flywheel lightened for a snappyer throttle response, or buy an ancient CR5 (CR500) and just ride that in the sand.
Posted March 04, 2005 - 05:03 PM
If your speed is only 1 mph different between two different gears, that should tell you that gearing isn't going to help this particular situation much one way or the other. I would say that you have a traction issue, and that your current tire isn't going to push you up the hill any faster. Try a paddle or add 5 horsepower (the tire is cheaper).
  • noslo98
Posted March 04, 2005 - 05:51 PM
I am already running a paddle im not that stupid to go all the way up there with out a paddle. I was just wondering since i have raced two stroke 250's with a weight and it helps them a lot but they dont have the torque to start with so i guess they need somthing to make it.
  • SSpeeDEMONSS
Posted March 05, 2005 - 09:27 AM
what kind of paddle are you running? that can make a big difference. number of paddles, paddle design, paddle size, they can all affect it.
  • noslo98
Posted March 06, 2005 - 06:43 AM
I am running an 8 paddle cuurenly i ran a 10 the first time i went up and was getting beat by my friend on a crf with a 8 so i switched and it seeems to work a lot better. i think the 10 hooks up a little too much plus the extra weight.
  • SSpeeDEMONSS
Posted March 06, 2005 - 12:15 PM
what kind of paddle is it? one of those chen-shing's? or a hooker? if you dont already have one try a hooker. i run a 10 paddle sand snake right now but im going to switch over to an 8 paddle hooker or possibly 10 paddle hooker next season depending on the mods i do this summer. the hooker might make a difference if you dont already have one. try it, if it doesnt help at least you have a better paddle.
  • ISBB
Posted March 06, 2005 - 02:54 PM
I run a kings turbo paddle 8 blade on my wr426... I can keep up pretty well but w/ my fat butt hill shooting sucks... I usually do 4th gear rides w/ all my buddies and its a blast and have no problems once i hit 4th just keep the rpms up and your set... :)
  • noslo98
Posted March 06, 2005 - 05:19 PM
the 8 paddle is a kings turbo and the 10 is a shing shin dune hopper i was thinking of getting a better quality one like the skat trak but was not sure if it would make that big of a diference. I like the turbo because it has the cleets on the sides wich seems to hlep when your tring to ride on the side of the hilll. and i also run the kings front sand rib it helps a lot also.
  • On January 15, 2017
  • 5 replies
  • Hot  30 replies
  • Hot  50 replies
