how hard is it to replace fork seals
20 replies to this topic
  • ThumpaWR450
Posted March 04, 2005 - 08:47 AM
I have a 04 WR 450 and the frok seals went out on me a couple weekends ago and I was wondering how hard it was to replace them. Could I do it myself or should I take them in to be done. If I can do it my self what do I need to do everything right the first time. Thanks for all your help.
  • wrooster
Posted March 04, 2005 - 12:13 PM
from
http://www.thumperfaq.com/sitemap.htm
see
http://www.thumperfa.../fork_seals.htm
and
http://www.thumperfaq.com/fork_oil.htm
jim aka the wrooster
'01 wr250f
  • ThumpaWR450
Posted March 18, 2005 - 08:46 AM
OK thanks for your help. I am just going to send them in to have them done. It is going to be 70 dollars plus parts so it shouldnt be to much and t will make it eaisier on me. Thanks again.
  • mjslim
Posted March 18, 2005 - 11:48 PM
While you got the forks off, you might want to consider some Seal Savers to go with the new seals. Folks here swear by them - cheap investment about $25 or so.
www.sealsavers.com
  • ThumpaWR450
Posted April 05, 2005 - 07:07 AM
I will look more into doing that. Thanks
  • trickwarrior
Posted April 05, 2005 - 08:19 AM
Just did mine last weekend and it was pretty easy. Remember to get some seal savers from the above link. well worth it
  • ddialogue
Posted April 05, 2005 - 09:32 AM
I don't know about you guys but I have a really hard time paying $70 plus parts for something I can do myself. The only hard part about replacing the fork seals is driving the seal in. $70 can get you your very own fork seal driver that you can use over and over again. Fork seals can and will go out (with and without Seal Savers) and $70 plus parts can really add up fast. Just my opinion. :naughty:
  • Jackazz
Posted April 05, 2005 - 10:10 AM
So far I've kept my OEM seals "alive" with lots of leftover 35mm film negatives, brake parts cleaner & a bit of sil-glide under the dust seals, but I'm gonna change them out soon (only about 300 miles on the bike). I traded PM's with Rob from Synergy Fork Seals awhile ago, & was pretty interested in what he had to say. If his webpage had nearly as much info about his products as I got from him he'd probably sell alot more seals. I called him & left a message today, as I want to order a set. I'll give a full repot once I've had a chance to install & trail test them. :naughty:
  • stonewall
Posted April 05, 2005 - 07:50 PM
Replacing the seals is an easy job. Save the $70 for beer money. :naughty:
Instead of SealSavers give ShockSox a try. $27.95 shipped to your door. http://www.krewmx.com/
They work just as well and can be installed/removed in seconds because you don't have to pull the forks. It's a sweet design that makes it easy to keep the seal area clean. :D :naughty:
  • Indy_WR450
Posted April 05, 2005 - 10:12 PM
Dave is right. I had my first seal go on my fork because I got lazy on cleaning under my seal savers when riding a lot of month last month. Dave showed me how to do it on the inverted forks in Moab last week! :naughty: Was not bad but it helps to have 3 hands! took us about 20 minutes total time. :D Thanks dave I ordered the Race tech seal driver yesterday! :D
  • WR450_in_Turkey
Posted April 05, 2005 - 10:33 PM
Those "shock sox" look cool! Will get some of those. My own bike is on 4500kms and still on the OEM seals but they are cleaned and greased as per the manual after every run. I have replaced a them on a friends bike though and its quite easy. Use the labour money on beer to drink while you are doing it. :naughty:
  • ThumpaWR450
Posted April 08, 2005 - 07:57 AM
OK thanks for your guys help. But I am still not sure if maybe one of you guys could explain quickly how its done then maybe I will decide to do it myself and save that money to add the dual sport kit to it I want to.
  • ddialogue
Posted April 08, 2005 - 08:24 AM
I'd love to give you a brief description but the Yamaha Owner's manual would put me to shame! :naughty: In the manual it shows you step-by-step how to do it and provides pictures.
Really, though...it's a very easy process. :naughty:
  • mtrablue
Posted April 08, 2005 - 08:32 AM
if your fork seals are only leaking, try the film negative trick. slide the wipers down and run a peice of film negative up under the seal. slide it around the fork tube and then out. you'll be suprised at the dirt you will find. do this till no more dirt comes out. never power wash around the seal area and always wipe dried mud and dirt off your forks.
as far as changing the seals, your manual is very good and covers the process very well. i doesn't hurt to watch a buddy do it first. it's kind of strange the first time you pull the forks apart. you'll wonder if your going to damage anything. the manual tells you to replace the bushings also. it's no needed if they have not been dinged up. check for a burr where the two bushings hit each other during disassembly. try to smooth out the burr with out doing any damage to the teflon coating on the (the grey stuff).
  • ThumpaWR450
Posted April 11, 2005 - 07:20 AM
I am going to try that this weekend then. Thanks for all your help. I will let you know how it goes.
  • ThumpaWR450
Posted April 15, 2005 - 07:19 AM
Well I have started taking my forks apart and it is pretty easy. I cant put them back together yet because one of the springs broke. I have ordered it and I will get it Saturday and finish the job. Thanks again for all your help it was pretty easy to do.
  • Jackazz
Posted April 15, 2005 - 07:45 AM
Dude, you broke a fork spring!?!? :naughty:
  • ThumpaWR450
Posted April 15, 2005 - 08:02 AM
Yeah and I have no freakin clue how. I am going to call up my yamaha dealer and see what they say
  • trickwarrior
Posted April 15, 2005 - 10:04 AM
Please post what the dealer says bout the broken spring. I did mine a few weeks ago and they turned out great. I used PJ1 Comp oil and they feel great. I was told by the tech at the dealer here that it is just as good as the recommended 01 yamaha oil and half the price. :naughty:
  • ThumpaWR450
Posted April 19, 2005 - 07:33 AM
I called up the Yamaha dealer the other day and talked to the service manager and he said that he isnt real sure how it broke. He said I must of landed hard on a jump after there was no oil in the forks. He wasnt real sure and neither is any one else I have talked to.
