Countershaft sprocket removal tips?
5 replies to this topic
  • Fryboy
Posted March 03, 2005 - 05:21 PM
Hi everyone,
Anyone have any tips?
  • new2blu
Posted March 03, 2005 - 07:18 PM
1. Remove guard
2. Bend back the "lock washer" from around the nut
3. Remove the nut with a large socket---Be sure to put bike in gear and apply the rear brake to keep the sprocket from turning freely
4. When installing the sprocket--bend the washer over one of the "flats" of the nut to keep it from coming loose. I guess this is kinda like a lock washer
  • Indy_WR450
Posted March 03, 2005 - 08:03 PM
Rear brake is usually not enough so you may want to put your foot into the knobs on the top of the tire. Tie the break lever in the position for full lock. :)
  • markyjoe
Posted March 04, 2005 - 07:14 AM
I used an impact gun to remove the nut but not to tighten it. Torque wrench, in gear, and rear brake applied to tighten it.
  • postalrider
Posted March 05, 2005 - 08:44 PM
NOW THAT YOU HAVE IT UNDER CONTROL BE SURE TO PUT YOUR OLD SPROCKET IN YOUR TOOL BOX 450s are known for shreading a front sprocket without warning
  • Sylvain
Posted March 07, 2005 - 02:20 AM
Just to add what new2blue said, Use a torque wrench to tighten the sprocket nut .
