04 yz450F coolant change
2 replies to this topic
  • Toobold30
Posted February 26, 2005 - 11:22 PM
Hey guys..i have not got a manual for my 04 Yz450f.. Im getting ready to change the coolant and would like to get some detailed steps on how to do this...I think im going to use engine ice....thanks everyone
Posted March 02, 2005 - 08:32 AM
At the lower edge of the water pump cover, you'll find a bolt with a copper washer under it. That's the coolant drain. Remove the radiator cap, drain the coolant, refill with distilled water, and run it for 2-3 minutes. Then drain it again and put your new coolant in. Be sure to double check for a complete fill after you run it a while, bubbles may become trapped when you fill it and work their way out to the top later.
Always be extremely cautious of removing the radiator cap from a hot engine. Let it cool for at least ten minutes, wear gloves, keep your face back, and let the cap release pressure at the first catch point when unscrewing the cap. Fooling around with hot coolant is an easy way to get burned worse than you ever did on an exhaust pipe.
  • ncmountainman
Posted March 02, 2005 - 08:54 AM
i've found if you fill the rad about half full(after it all settles in)and rock the bike side too side as far as you can(w/out spilling it back out) ,it gets out the trapped air out better :)
  • 0 replies
  • Hot  38 replies
  • Hot  113 replies
