03 charging system
2 replies to this topic
  • scheffaa
Posted February 25, 2005 - 04:01 AM
i bought my 03 wr450f brand new from the dealer mid year 2004. when i got it the battery was dead because it had sat in a showroom for nearly two years. i replaced the batter with the corect one but the bikes charging system seems to be having trouble charging it. it is a breeze to kik start but seems a waste to have an electric start and only be able to use it sometimes.
  • mjslim
Posted February 25, 2005 - 12:55 PM
I've never had a problem with mine, but for starters I would check to see that your charging system is putting out the proper voltage when the bike is idling. Assuming it should work similar to a car's system (you electrical weenies may want to jump in here), I would think the voltage across the battery leads should be in the 13.5-14.5 volt range when the bike is idling. Start the bike up, put a volt meter on the leads and see what you get. Also check to see what the manual has to say about checking the charging system.
  • ETP
Posted February 25, 2005 - 04:40 PM
Ditto what mjslim says.
Also, the WR450 charging system is not a real powerful. It seems have enough juice to keep a well charged battery charged while riding, but not enough to recharge a weak battery while riding.
At the advice of some fellow TTr's, I just bought a Battery Tender Jr. which charges my battery in the garage the night before riding. $29 at Pep Boys. :)
