Valve Check; When
8 replies to this topic
  • WGP
Posted February 24, 2005 - 02:58 PM
Got the 05 WR450, thinking 300 miles will be the time to give the valves a clearance check? Then how often?
  • mountainriderWR400F
Posted February 24, 2005 - 06:45 PM
It is easy to do and I would say about every 500 miles its quick and if there is a problem better to know sooner than later. Enjoy the new bike and keep the wheels down :)
  • moach1
Posted February 24, 2005 - 07:47 PM
is there any pics of how to do the valve check? never done one, and i would like to do it myself. thanks
Posted February 24, 2005 - 08:20 PM
go to this site:
http://www.thumperfaq.com/valves.htm
Then use these directions and you should be fine:
YZ250f/400/426, WR250f/400/426 Valve Adjustment Procedure:
Remove seat, tank and shrouds
Remove breather hoses from top of engine cap.
Remove the spark plug.
Remove the top engine mount brackets (12mm, 14mm and hex wrench needed)
Remove the two engine cap screws (hex wrench needed).
Remove the engine cap taking care not to damage the gasket.
Remove the two timing caps from the left side of the engine crankcase (standard screwdriver)
Using a 14mm socket, align the timing mark ("I" not the "H") with the marks on the cover for the compression stroke (cam lobes should be facing away from each other). The marks on the cams should also match up to the top of the engine per WR or YZ timing.
Using a feeler gauge, you should be able to check all your valve clearance numbers.
Start with the manual specs and shove the feeler gauge under the cam lobes. If it won't go under, go down until it does. If it goes in to easy, go up. I beleive there should be a slight resistance when checking the correct clearance but it should slide under the lobe.
Compare your numbers with the manual's specs. If they are not in specification, then you will need to change out your shims.
Make sure you keep track of which clearance measurement goes with each valve as you will have to match them up with shim numbers if you need to adjust them. That is all you need to do to check your clearance. :)
  • HighPlainsWR
Posted February 24, 2005 - 08:29 PM
WGP,
I have 300+ hours on my 03' WR450 and I have the valve clearance checked once a year in the Spring. The only time one of the five valves was too tight was right after break-in in 03'. I short shift most of the time and don't over-rev the bike. I suspect the piston rings and/or valve springs will wear out sooner or later. If it's the latter case I bet I'll have a valve job, or worse, on the horizon. $$$$$ Time to trade in?
I could ask how many hours on a bike like the 450 can a rider expect before he should consider a new bike? The manual leads me to believe the motor should have been rebuilt many hours ago. :)
  • BEAN329
Posted February 24, 2005 - 08:55 PM
I have 2 years of racing on mine, just checked the valves all Ok. Piston and rings who knows maybe next year. So far no smoke and tons of power, so let her ride. :)
Posted February 24, 2005 - 08:57 PM
I guess it would depend on your riding style and maintenance of the bike I have been riding two strokes since way back when and I finally got a 99wr400 back when and I still love it today I was intimidated from the complex motor compared to the simple two stroke. But a simple service manual and the time and patience I can do anything that I need and if it is something that I cannot do I can remove the parts or pieces and bring them to the dealer and after repair just bring home and re install and save a lot of money. I look at it like an old truck or car just take care of it and do a lot of maintenance. :)
But then again there are people that buy a new bike every so many years like it is clapped out or something. Which is cool if you can handle the constant payments :) I am thankfull for my Blue beast and just enjoy what I have and worrie about a new bike if ever I need it at that time. Thats me though :p
  • elton
Posted March 02, 2005 - 03:48 PM
I believe the 2005 manual says initial @ 600 miles; then every 1200 miles.
Elton
  • 450high
Posted March 04, 2005 - 02:31 AM
2300 k's and just checked again and all appear spot on.
