Which oil filter to use--stainless steel or stock?
6 replies to this topic
  • Potato_Thumpin'
Posted 28 January 2002 - 05:32 PM
Does anyone use the Scotts stainless steel oil filter? It says it can be washed, but the picture looks the same as the stock part? How is it different from stock? What gives??
  • randyWRF
Posted 29 January 2002 - 12:33 AM
You already answered one of your questions. The difference is it IS stainless steel.
Yes it can be washed about a zillion times with brake cleaner.
It traps WAY smaller particles than the cheap stocker. I put mine in at the first oil change and never looked back.
Randy
  • MxHuggy
Posted 29 January 2002 - 03:36 AM
I agree with Randy, it is much more durable than the stocker. You will see that when you change the oil. It is pricey but, very high quality and you will never buy another filter again. I clean mine with some contact cleaner and then blow it out with a compressor. I don't think the stacker could take much of that. Good luck.
  • smitty33
Posted 29 January 2002 - 04:54 AM
We did a test on the scotts filter a couple weeks ago, check it out here:
http://www.fastbydes...tts_Filter.html
or email me if you have any more questions
  • JBM
Posted 29 January 2002 - 07:21 AM
The stock filter works just as well as the Scott's. Maybe it filters a few minutely smaller particles but is that necessary? You can clean one many times before it needs replacing. I keep a spare on hand in case of tears or breaks but have never had one. It lasts quite a long time. You can easily get 6 months out of one. I finally replaced it just because I felt bad. Just inspect and clean regulary and keep an eye on the rubber seals at each end.
  • johnmac
Posted 29 January 2002 - 12:59 PM
very interesting smitty33.
i will buy 1 asap.
thx.
  • smitty33
Posted 30 January 2002 - 05:51 AM
It really is an excellent product and much more durable than a stocker
Thx :)
[ January 30, 2002: Message edited by: smitty33 ]
