Heavy Clutch
9 replies to this topic
  • woodsk
Posted February 22, 2005 - 06:30 PM
do you guys have any suggestions for lightning up the clutch pull on an '04 450?
  • xcracer123
Posted February 22, 2005 - 06:44 PM
Buy a Rekluse! :) Seriously though, if you don't want to go that route you can lengthen the actuator arm on the case or get a hydraulic clutch or you could get one of those easy pull clutch assemblies. Hope this helps!
The Rekluse is the way to go though. It's the most amazing mod I have ever done to any bike! Makes it SO east to ride. :)
  • mtrablue
Posted February 22, 2005 - 08:21 PM
my '03 was the same way. i've got a rekluse now, so it's not an issue but i did notice that the '05 is supposed to have been updated. you'll have to do a little part number checking but it might be as simple as an '05 lever and bracket to get an easier pull.
  • gregwr450f
Posted February 22, 2005 - 10:13 PM
When your checking out TT or watching tele squeeze a tennis ball,
In my line of business I have to hold a 4000 lbs pressure line with my left hand and I can hardly feel my clutch, I think it's to light.
Squeezing a ball is free. (Tennis ball I mean)
  • woodsk
Posted February 23, 2005 - 06:32 AM
Typically my ball squeezing has been done right handed (and hopefully someone elses hand) :)
I do agree that I need to increase my forearm strength however, I would like a lighter pull as well.
Thanks for the input
  • NewBlue
Posted February 23, 2005 - 06:39 AM
I was considering the rekluse, but several posts on here have pointed out that the bike is difficult to return to neutral. Some have also stated that they were just real tempermental.
  • xcracer123
Posted February 23, 2005 - 06:15 PM
If you do decide on the Rekluse make sure you get the perch adjuster. Then there are no issues with finding neutral. The lever overrides the auto system and then you can find neutral right away.
If you install the Rekluse properly and make sure that you check the gap periodically you will have no problems with it. Granted, I only have one trail ride and one race under my belt with mine BUT my buddy ran one all last year in his RMZ and had no problems with it and didn't even have to reset the gap. :) Hope this helps you out.
  • JVP
Posted February 23, 2005 - 06:37 PM
The clutch pull has a lot to do with the clutch springs. I recently replaced my clutch with an aftermarket assembly from EBC. I found the spring appeared to be bigger and heavier. After putting the clutch in I found the clutch pulled a lot harder. I used to have a CR500 so I am kinda use to it. I had a EZ Pull adapter for that bike and it did help. I am sure you can find lighter clutch springs if you can not handle the stock clutch pull. :)
  • jerryls
Posted February 23, 2005 - 09:19 PM
I've got 3 hare scrambles and about many miles of trail riding on my Rekluse. It's been a godsend. Can't imagine going back to a normal clutch. It has work as promised and has never been tempermental. I did add the five TC balls for quicker engagement off idle, but that's all I've changed from the normal setup. I guess if you installed the wrong spring for your riding style, it could qualify as termpermental. But that can be rectified by using the correct spring.
And I don't understand what the problem is with finding neutral. Sure it can be a little tough to find if the bike is running, but why do you need it? The bike will idle in gear, and you can start it in any gear with the Rekluse. The only time I need to find neutral is to back the bike out of the truck.
You should reconsider getting a Rekluse. Go over the old posts here and you'll find 95% of them are positive feedback.
Jerry
  • RichBaker
Posted February 24, 2005 - 10:08 AM
Who needs to find neutral with an auto-clutch? I have a rekluse and don't worry about it...I even leave her in 1st when I get off to open a gate. Never had a problem yet....
