Throttle Problem. Its sticking.
13 replies to this topic
  • Scarylong
Posted 27 January 2002 - 01:29 PM
I went to the track today, bike was working fine.
After I washed the metric tonne of mud off of it, I started it up. I noticed that the throttle just stuck where ever i put it. It also feels a bit tight. Any thoughts guys. I know this is the lazy to fix something, but I am kinda new at the BIke mechanic thing and I know you guys (collectivly) know plenty.
Only thing I have changed near the throttle is I put on a Dr.D hot-start yesterday.
Thanks.
S.
  • jsmith811
Posted 27 January 2002 - 02:26 PM
My 02 yzf 250 has done the SAME thing today, I hope its just dirt or something?? but the throttle is very slow to return, it does return, but I intend to tear it down tonight and see what I can find.
  • Scarylong
Posted 27 January 2002 - 02:35 PM
I wonder if they all did that today? :)
Let me know what you find.
I Was just going to go down and take mine apart also.
  • fndaway66
Posted 27 January 2002 - 02:36 PM
Scary,
Check the pully wheel on the carb. Just unscrew the black cover on the right side of the carb. You will see the pully wheel and the throttle cables. Turn the throttle back and forth to make sure the cable is tracking true on the wheel. look for any frays on the cable. There seemed to be a problem with some "01" 426/250F's pully wheels being misaligned and fraying cables.
  • osheen
Posted 27 January 2002 - 02:52 PM
Make sure that the throttle tube is not pushed all the way up against the end of the handlebar. It should have a little bit of play from side to side. About 1-2mm.
  • 250F#8
Posted 27 January 2002 - 03:00 PM
Quote
Originally posted by fndaway66:
Scary,
this did happen to me
  • motocross117
Posted 28 January 2002 - 06:29 AM
CLEAN THE THOTTLE TUBE EVERY RIDE IN THE MUD OR THE SAND!!I LEARNED THE HARD WAY MINE STUCK OVER A DOUBLE AND I CRASHED HARD HAD TOO HAVE ACL REBUILT IN LEFT KNEE NOT FUN
[ January 28, 2002: Message edited by: motocross117 ]
  • mikeolichney
Posted 28 January 2002 - 03:43 PM
Alot of times what happens is you drop the bike on the non-throttle side. It tears the grip and puts dirt in the handlebar. Then the dirt collects in the bar by the T clamp. Guess what happens next time you lay the bike on the throttle side? All that dirt goes right on the throttle.
Some people put coins in the grips to cut down on this. I would plug the non-throttle bar end with silicone instead. But even better is to use bar ends. The ultimate is bar ends and a AL throttle tube.
A stuck throttle can get you killed. Fix it ASAP.
  • Scarylong
Posted 28 January 2002 - 04:23 PM
My bike looks brand new. No dirt in the bars, no rips in the grips. I did drop it on the right side ( it fell (again :) )) could this push the tube causing it to rub? I am going down after I eat. I will let you all know what I find later.
  • osheen
Posted 28 January 2002 - 04:39 PM
Absolutely!!
  • Scarylong
Posted 29 January 2002 - 08:24 AM
I got it fixed. I pulled off the throttle wheel cover. I sprayed the wheel with some WD40. I hope that was not a bad idea. Thanks for the help. :)
  • Dennis_Van_Dyke
Posted 29 January 2002 - 09:12 AM
I've always wondered whether you could or should use your cable lube stuff instead of WD40 on those kind of things?
  • Scarylong
Posted 29 January 2002 - 09:25 AM
It was not a cable problem. I sprayed behind the wheel. I just worry that dust might accumulate even more with the WD40.
  • z4me
Posted 29 January 2002 - 09:33 AM
A great trick is to spray your whole engine down with WD40 after you wash it. Next time you ride it will collect much less dust mud dirt etc...
To answer your question - no it shouldn't cause more dirt to stick under there. You might need to do it regularly due to WD40s tendency to evaporate though.
