Help..... Bad Misfire
2 replies to this topic
  • Stonie426
Posted February 22, 2005 - 02:17 AM
Anyone know what might be causing this....
'04 WR450 symptoms:
At between 20-25 mph, seems to be a complete misfire or very bad stutter resulting in a jolt every 20 yards or so.... at higher speed it's OK.
Jetting - OK with PJ/PS/PAJ: 48/1.5 turns/100, Needle/Clip: EMN/4, MJ/MAJ: 170/200, LJ: 40, Idle: 1800 rpm (approx).
CDi output voltages - OK
Coil secondary winding - OK, unable to check primary winding as meter is not accurate enough.
Plug - OK
In the middle of checking all other wiring, connections, grounds etc - haven't found anything obvious yet.
Any help out there....
  • buck_y_lee
Posted February 22, 2005 - 03:21 AM
I know you say you've checked, but sounds like plug or bad ground connection to me.
Similar to bad ground connection, any water in the plug well?
  • Seabass
Posted February 22, 2005 - 07:07 PM
Same thing is happening to me, but mine started after I put on a new exhaust
