loseing bottom end?
4 replies to this topic
  • twopumpthumper
Posted February 21, 2005 - 04:02 PM
I've noticed since I switched to a 18 inch tire I lost some bottom end I'm running a 49 in rear and stock in front? What do you guys think? I had tons of slop in my chain as well the tire seemed to move forward?
  • sanpedro426
Posted February 21, 2005 - 04:57 PM
Whether you have a 19 or an 18 inch tire has no effect on the gearing because the outer diameter of the tire is not different. The 19 inch wheele is bigger yes BUT the side wall of the tire is shorter, making a stiffer feel to the rear end. 49/14 IS stock if its a 426. If your wheel moved forward its because you failed to properly adjust the jamb bolt/nuts properly. :)
  • twopumpthumper
Posted February 21, 2005 - 05:36 PM
tHEN WHY THE POWER LOSS?
  • ncmountainman
Posted February 22, 2005 - 07:30 AM
the 18" tires are heavier,just consider it a little more flywheel effect :)
  • sanpedro426
Posted February 22, 2005 - 11:22 AM
CORRECTAMUNDO :)
