what gearing are you track and tight trail riders using
8 replies to this topic
  • rljjredhed
Posted February 21, 2005 - 02:34 PM
looking for 2003 info, or do you guys just switch the front sprocket thanks
  • ONLY4STROKES
Posted February 21, 2005 - 02:37 PM
I seem to be getting along fine using the stock gearing. Renthal sprockets/chain.
Doug
  • MO_YZ450F
For trail riding (what I mostly do), I went to a renthal 13 tooth front sprocket. Considering going 49 tooth back as well. I've heard flywheel weights are good too for series trailriding (mountains and such), but you would want to take it off for track most likely.
Posted February 21, 2005 - 02:47 PM
I run 15/49 everywhere. A little tall, but it works for me.
  • Jetsprint2
Posted February 21, 2005 - 02:58 PM
14/48:stock. This gearing works very well for me but I am only 5'10" and 155lbs. Heavier guys may want to go up in back or down on the front sprocket;note a change on the front sprocket is worth like 3-4 teeth on the rear. :)
  • olympus
Posted February 21, 2005 - 07:45 PM
I just switched back to 14/48 from 14/49. Believe it or not I'm actually stalling the bike less with the 48.
  • curtis515s
Posted February 21, 2005 - 08:15 PM
Tryed a lot of combo's. Ended up with the stock 14/48.
  • Jetsprint2
Posted February 22, 2005 - 07:41 AM
MXA magazine says that 14/47 is even better for less stalling. The gear ratio spins the engine faster and helps with stalling.
  • Baycrosser
Posted February 22, 2005 - 08:13 AM
Makes sense to me
  • Hot  50 replies
  • Hot  47 replies
  • 10 replies
