Screen Oil Filter In Yz450 Frame
7 replies to this topic
  • HIGH COMPRESSION
Posted February 21, 2005 - 02:24 PM
I Change The Oil In My Yz450 After Every Ride. But I Don't Always Clean The Screen Filter In The Frame. How Often Should I Clean That Filter.
  • DoctorRzed
Posted February 21, 2005 - 02:39 PM
Your wasting you money changing your oil every ride. I only change mine after 3 races.
  • ONLY4STROKES
Posted February 21, 2005 - 02:40 PM
Back to his question, I would like to know this as well. I've only cleaned the screen filter in the frame once.
Doug
Check when you first get the bike to look for left over sealer, etc., from assembly, after you do any major work on the bike (for the same reason), and any time there's reason to be suspicious. Otherwise, once or twice a year is probably good enough.
  • ONLY4STROKES
Posted February 21, 2005 - 02:41 PM
Thanks grayracer, good info to have. I hate not doing exactly what the book says.
Doug
  • tnl
Posted February 21, 2005 - 07:37 PM
The book say's "every oil change inspect the strainer". It's a pain in the a__ to remove the strainer!
Posted February 21, 2005 - 08:07 PM
The book is attempting to tell you how to do things 100% right. In this particular case, except for those times I mentioned, it may be 100% right, but it's only about 2% necessary. It could be said that you're taking a calculated risk if you don't check it, but IMO, it's a pretty small risk.
Look at it this way, that's the screen from the oil supply to the feed pump. How often does that same screen get checked on a wet sump? :)
The fact that it's on a dry sump bike just makes it more practical to check at all. It doesn't make it mandatory.
  • yz450fensenada
Posted February 21, 2005 - 08:40 PM
well i havent cleaned mine since i bought the bike in november 2004 well ... the reason is that the who ever assembled this part ( yamaha i guess ) tightened its bolt way too tight ... soo tight that when i tried to bust it loose i striped it and ripped a big chunk of skin of my knuckles soo i said screw it ... but hey is this really bad ... for me havent cleaned it too?
  • Hot  50 replies
  • Hot  47 replies
  • Hot  30 replies
  • 5 replies
