426 Gearing
5 replies to this topic
  • FZ1426
Posted February 20, 2005 - 07:34 PM
I'm experimenting with the final ratio so I can switch from desert to track by just changing the countershaft. I'm currently running 15/50 for desert but find it a tad too high. 14/47 was perfect. If I go 13/47 for the track will it cause the chain slider to wear too close to the swingarm? Any other problems running a 13 countershaft?
  • dirtbikindad426
Posted February 20, 2005 - 07:41 PM
I run 14/49 track and 15/49 desert this has worked out great for me only changing the c/s sprocket when I change.
Now all I need is a stock tank to change back to for the track.
  • FZ1426
Posted February 20, 2005 - 08:34 PM
Wow, that's even higher. Good for goin' fast but you sure loose a lot of punch gettn' there...
  • NevadaCR500
Posted February 21, 2005 - 10:09 AM
What is stock on these things, I bought my bike used and it has 15/50.
  • FZ1426
Posted February 21, 2005 - 11:23 AM
Stock is 14/49.
  • YZ426FPilot
Posted February 22, 2005 - 10:10 PM
Stock is 14/49. I run 15/49 everywhere and love it. You shift less & I always thought it pulled harder. Just doesnt have that snap in 4 gear anymore but its still fast. It helps if you have a magura hydro clutch though, you can control the power to the rear with a lot more precision. I was going to add weight to the flywheel, but not now.
  • 0 replies
  • Hot  79 replies
  • 9 replies
  • 5 replies
Need help by Goforaride
  • Hot  68 replies
