Need info on forks on my 02 xrl 650
No replies to this topic
  • hoptup
Posted February 20, 2005 - 07:23 PM
I recently bought A 2002 XRL 650, come to find out the left front fork housing is dented bad enough that the seal is leaking (right at the very top 1/2 inch) and the what appears to be brass cap is bent but still flush. I am sure the housing is dented, can it be beat back good enough so it will work ,or is that something I need to replace- I might be needing a set of forks, at least the left one if anyone has one for sale. The fork isn't holding fluid, with very little air applied (4psi) not safe for much of anything. :) :)
