05 breather pipe
4 replies to this topic
  • gregwr450f
Posted February 20, 2005 - 03:14 AM
I notice on the 05 wr450 the breather pipe go's into air filter box, unlike the 04, would it be a good idea to remove it form there and have it go down the same as the 04 so it is not sucking hot air. :)
Nitros oxide work by putting extremly cold air into the motor which gives more horses (I think)
  • Indy_WR450
Posted February 20, 2005 - 04:46 AM
No you want that Mod! For deep water crossings if you stall you wont suck up water like the 03 and 04's would when starting it up again. :)
  • gregwr450f
Posted February 20, 2005 - 05:08 AM
Good point Indy, but how about a one way valve installed on on the pipe?
  • Indy_WR450
Posted February 20, 2005 - 06:23 AM
Bad idea. The breather needs air flow in both directions to keep oil flow going through your bike frame and engine properly. I would not recommend the one way valve. Too risky in my opinion. :)
  • gregwr450f
Posted February 20, 2005 - 06:30 AM
Thanks Indy,
That puts that idea to rest :)
