Bike chain is binding
6 replies to this topic
  • HondaXR650L
Posted February 19, 2005 - 05:32 PM
My bike chain is binding. The links are bunching up, how do I fix it and what do I use to keep it loose? I bought the bike used and am still try'n to work out alll the bugs. :)
  • frankstr
Posted February 19, 2005 - 06:47 PM
Try cleaning it with kerosene, Soaking it if possible and lube it well after it's clean........
  • Brianc
Posted February 19, 2005 - 06:52 PM
oil it well, then ride it for a short distance, then remove it and soak it again. If it still binds, then it is time for a new chain; always replace the sprockets when you replace your chain
  • grreatdog
Posted February 19, 2005 - 07:46 PM
Everytime I had one do that it was toast. You can try soaking it, but you are most likely looking at buying a new one.
  • XR650Rrider
Posted February 19, 2005 - 09:59 PM
It will start eating sprocket teeth shortly if it hasn't already. Look closely for broken teeth.
  • HondaXR650L
Posted February 20, 2005 - 08:47 PM
Oil the chain, what's the best stuff to use? No broken teeth yet, and no wear showing, yet.
  • tullymars
Posted February 27, 2005 - 06:14 PM
Take it off and throw it away,go buy a good NON O RING chain,keep it oiled and it wont bined.Dirt gets in between the o rings and causes binding,usually its irreversable.
