Yoshi Pipe on WR426?
3 replies to this topic
  • NewBlue
Posted February 18, 2005 - 08:13 AM
Does anyone here run the Yoshi slip-on or complete system? Is it worth the $$$? Secondly, after I drained the break in oil, the stuff looked almoist gray. Is that normal? Thanks in Advance
  • Indy_WR450
Posted February 18, 2005 - 09:10 AM
Dark gray/ brown is normal. Black is to rich and Gray is to lean. You may want to rejet to eliminate the lean spot. :)
  • NewBlue
Posted February 18, 2005 - 12:14 PM
Thanks Indy. This was the first oil change, does that make a difference?
  • Indy_WR450
Posted February 18, 2005 - 12:26 PM
No matter if it is the first oil change or type of oil it should make no difference. The exhaust color will be set by the combustion fuel/air ratio for the most part.
