WR450 sprocket
4 replies to this topic
  • Dirtmizer
Posted February 17, 2005 - 03:58 PM
I'm thinking of going up a tooth on my front sprocket for easier road cruising, what brand should I buy? and will I notice the lack of low end on the trails? or should I plan on swapping back and forth? I ride mostly tight stuff up north and more dirt roads and streets at home so swapping back and forth would be ok. Thanx.
  • RichBaker
Posted February 17, 2005 - 04:12 PM
When I did that, the stock 15t replacement(with rubber damper) was the least expensive of any my LYD had....
  • markyjoe
Posted February 18, 2005 - 06:59 AM
Bump...Same situation, I'd like to go up to a 15 front for higher speed desert riding. Any opinions? Thanks.
  • ncmountainman
Posted February 18, 2005 - 07:26 AM
just do it! the 450 has plenty enough power to pull a taller gear. :)
  • doctorchopper
Posted February 18, 2005 - 10:38 AM
I just went from a 14 to a 16, with a 46 on toothon the back on my 426, i noticed a bit of power loss in 4th and 5th gear, but still pulls like a rocket, and now i cruise around 60 to 70 mph without having to rev the piss out of it, top speed of around 90-100mph, I am running supermoto tires and rims so the back tire is a little smaller
