oversized header question
3 replies to this topic
  • Hurricane
Posted February 16, 2005 - 11:28 AM
My stock header is smashed and I have an oversized header, tapered. The tapered header has a larger diameter hole than the outer diameter of the midpipe. The header slips over the midpipe, but it is a tight fit. Will it work this way with some high temp silicone or will it leak exhaust through the connection? Or maybe some high temp exhaust tape?
  • Indy_WR450
Posted February 16, 2005 - 02:35 PM
Just sounds like a bad idea. Usually the header fits inside the mid pipe and then if you need to you can use high temp gasket & silicone to fill the gap.
The step is just going the wrong way and your seal will just get hammered by the exhaust gases. :)
  • Hurricane
Posted February 17, 2005 - 06:31 AM
That's what I figured but I though I'd ask anyway.
  • sharpmarble
Posted February 17, 2005 - 08:17 AM
Here's one on ebay.....
http://cgi.ebay.com/...&category=35596
