rear tube keeps popping
8 replies to this topic
  • rasta
Posted February 15, 2005 - 09:46 PM
hello, yz 450 rear tube keeps ripping under valve stem nut, i used duct tape to wrap rim but still gets flat , also read in magizine that if you loosen the top nut half way on stem it helps, but still rips in same place, i only run heavy duty tubes, anybody have advice or hints that will help, thank you for your time, ---jah lives---
  • WRookie
Posted February 15, 2005 - 09:57 PM
Try a new rim lock with your next tube.
  • sirthumpalot
Posted February 16, 2005 - 04:25 AM
Agreed, also make sure your rim lock is tight.
  • rbm33
Posted February 16, 2005 - 05:52 AM
2 rimlocks
  • WRookie
Posted February 16, 2005 - 07:55 AM
Do you use any baby powder in the wheel? It's suposed to let the tube shift around some without binding. Your rimlocks should be snug not super tight.
  • Jackazz
Posted February 16, 2005 - 08:05 AM
Have you checked that there are no "burrs" or rough edges on the valve stem hole on the inside of the rim?
  • Yamaha600Racer
Posted February 16, 2005 - 08:18 AM
Had the same problem with my 426... Every time I would go out to the track almost, I would come home with a flat. Mostly happened to me in the whoops, put a hd tube in and made sure there were not any rough edges in the rim and didn't have a problem after that... Make sure to check the inside of the tire for a sharp piece of something that could have made its way in there :) Good Luck :)
  • motomike137
Posted February 16, 2005 - 08:31 AM
Also I would chuck the valve stem nut. If the tube/tire move on the rim then the stem can go along for the ride.
  • rasta
Posted February 16, 2005 - 11:39 AM
thanks for all the help will try all of your tips ,
  • 10 replies
  • On January 15, 2017
  • Hot  38 replies
  • 5 replies
