Odo drive eliminators
25 replies to this topic
  • Jackazz
Posted April 28, 2005 - 05:53 AM
#21
When did you get ahold of anyone at Barnums? I have left like 4 messages for them, begging for a call back about an odo. drive eliminator for an '05 wr450. I'm convinced they have gone out of business! The last time I left a message, I asked for a courtesy call just to tell me they don't have the spacer I want so I can go elsewhere to get one. :naughty: This has been over the span of a month, and not one call back. I am not at all impressed with Barnums at this point! :D
Sounds like you should call Flatland Racing, they're customer service & shipping are top notch, & very fast. :naughty:
1-877-375-5527
  • L8TBRKR
Posted April 28, 2005 - 02:36 PM
#22
Just remove the worm gear, cable etc., plug off the hole with a brass fitting and your done. Does the same thing as the machined spacer but for much less! Of course it doesn't look as trick though.
  • thumped_blue
Posted April 29, 2005 - 09:44 PM
#23
I would swear Barnum'sPro read my post. They called me today. Denise had been trying to get ahold of me but kept getting a wrong #. She was very nice and promised me a call when the odo. eliminators are fabricated. I take all that other stuff back. :naughty: She said Rob is now working with Big Gun...FYI
  • JeffWR
Posted May 19, 2005 - 04:48 AM
#24
You cant use the YZ spacer to eliminate the ODO unit! :)
Hey Indy,
I was thinking of buying the cheaper '05 YZ450 hub and right side spacer instead of the '05 WR hub and reusing the odo unit spacer, since I have the trailtech. So this will not work??? :D
Thanks for the help, Jeff
P.S. I want an extra rim mounted with trelleborg for winter riding.
  • Jackazz
Posted May 19, 2005 - 11:22 AM
#25
Hey Indy,
I was thinking of buying the cheaper '05 YZ450 hub and right side spacer instead of the '05 WR hub and reusing the odo unit spacer, since I have the trailtech. So this will not work??? :)
This will work ONLY IF you get the YZ hub. The YZ spacer does not work with the WR hub.
  • Indy_WR450
Posted May 19, 2005 - 11:35 AM
#26
If you really want to save money just remove the gear inside the stock odo unit and put a plastic cap on the cable connector and you have a poor mans odo eliminator. I ran like that for a year. :)
