Hard Clutch Pull Questions
10 replies to this topic
  • RCH_VisualMedia
Posted February 14, 2005 - 07:41 PM
My 03 450 has just recently started being super hard to pull in the clutch. Here is the facts as of now:
New Clutch Cable
New Oil
Original Clutch Springs
Friction Plates are at the minimum specs for thickness
Any ideas on making it not so hard?
Thanks! :)
  • ONLY4STROKES
Posted February 14, 2005 - 07:51 PM
Get softer clutch springs from Pro Circuit.
  • mikedabike
Posted February 14, 2005 - 07:53 PM
Make sure the cable is not kinked or routed funny. Also is the actuation arm installed correctly to get the proper leverage?
  • RCH_VisualMedia
Posted February 14, 2005 - 08:03 PM
The actuator arm hasnt changed, but what position should it be in?
Its still set like stock. Can worn out clutch plates make it stiffer?
  • yzf450jack
Posted February 14, 2005 - 08:17 PM
Is your basket all notched up :)
  • mikedabike
Posted February 14, 2005 - 08:20 PM
It should be at about a 90 degree angle, you can try moving ot forward or back one position to see if it helps. I dont think the worn plates would make it any stiffer but you should check your clutch basket for wear. The plate could be binding up a bit.
  • RCH_VisualMedia
Posted February 14, 2005 - 08:23 PM
My basket still looks brand new, no notches.
I checked the pressure plate and it is still good. Does the push rod have any bearings that could make it stiffen up?
  • mikedabike
Posted February 14, 2005 - 10:10 PM
You can take off the pressure plate and make sure the push rod mechanism is working smoothly. There isn't much to it. The cable attaches to the push lever which pushes the rod through the otherside of the engine when you pull the clutch lever and pushes the pressure plate out to take pressure off the clutch plates. If you already have it apart it isn't much more to take the push rod and push lever out and inspect for wear or damage.
  • alfie
Posted February 15, 2005 - 01:50 AM
This may sound stupid but have you lubed your cable :)
  • yz426onNOS
Posted February 15, 2005 - 09:40 AM
Sounds like a cable or perch problem. Something must be binding. Did you install the new cable properly? There is a certian way it needs to be routed for it to work propperly.
  • palmdaleRider
Posted February 20, 2005 - 05:30 AM
Also the pivot bolt at the lever needs to be clean. Mine was hard to pull yesterday and cable lube and a cleaned and oiled perch and now it's great.
Motocross
  • Hot  491 replies
  • 9 replies
  • 0 reviews
