Wheel Question?
4 replies to this topic
  • sldietz
Posted February 14, 2005 - 09:24 AM
I bought a used front Excel wheel and it's in pretty good condition..the only problem is when I bolted the wheel up I noticed a lot of play in it on the axle...the spacers are correct. I was wondering if it could be the bearings and seals that are bad? Any ideas?
Thanks.
  • Frostbite
Posted February 14, 2005 - 10:11 AM
Do you mean play like you can wiggle the wheel when the axle is tightened? If so, then most likely you need new wheel bearings.
  • Bamster
Posted February 14, 2005 - 07:52 PM
Definatly bearings
  • kenwen
Posted February 15, 2005 - 01:07 PM
Absolutly bearings. Had the same problem :) Replaced bearings, no problem :)
  • wr250rr
Posted February 15, 2005 - 05:27 PM
My front wheel had a little wobble from the spacer being worn.
