Shifter Suggestions ??
3 replies to this topic
  • 1biglung
Posted February 14, 2005 - 08:54 AM
I have tuna boat sive 14 feet and have IMS superstocker pegs on order. I have a hard time getting my foot under the stock shift lever. I have moved the lever up and is better but rides high on the downshift.
The question I have is:
Any suggestions on an aftermarket shifter that might be a little longer and have a little wider tip that might help?
P.S. this is for a XR650L
  • BajaBoundMoto
Posted February 14, 2005 - 09:06 AM
A lot of the aftermarket steel shifters are made by the same company, sold under different names, so it's not a big deal which one you get. They can also be too strong, they don't want to bend. If you hit a stock one it will bend and most aftermarket ones will not, instead bending the shift shaft.
If I were you i'd just have you stocker lengthened to make room for your boot.
If you have an aftermarket one lengthened have the welder do it so it creates a weak spot in the lever so it will be able to bend.
  • 1biglung
Posted February 14, 2005 - 12:43 PM
Cool, thanks for the advice.
I got an aluminium +20mm length and adjustable tip height shift lever on the way. Where else ?? The TT store.
Thanks Bryan !!!
  • qcustom
Posted February 15, 2005 - 12:44 PM
I welded a extra in. into a metal shifter works great for size 14 boots.
