pulls like a truck
17 replies to this topic
  • new2fourstrokes
Posted February 12, 2005 - 09:40 PM
2005 wr 450 pulls like a truck but wont rev :) is this normal? all free mods have been done plus have added the JD jet kit and screw. :) hard to explain but here goes... open throttle pulls real hard then nothin it just will not rev.. i might be way off I've ever had 2 strokes but does this sound right?????
  • Domenic_WRF
Posted February 12, 2005 - 10:03 PM
Mine revs to the moon :) Change your pipe? What needle and clip? Try raising the needle one clip (down with the clip) if you changed the pipe go up five numbers on the main. :)
  • gregwr450f
Posted February 12, 2005 - 10:08 PM
How many kms are on your bike ? At what speed (for each gear) will it stop reving ? Is your muffler uncorked?
  • new2fourstrokes
Posted February 12, 2005 - 10:22 PM
only done 300km the baffle is out umm as for the kit red needle 3 clip 168 can't remember the other... :)
  • gregwr450f
Posted February 12, 2005 - 10:28 PM
This may sound dumb but wait until around 1000-1200kms and after a couple of oil changes when it will free up a bit. Mine will rev till it sends my teeth blue, my mate was impressed and he is on a 250 2 stroke :)
  • new2fourstrokes
Posted February 12, 2005 - 10:57 PM
bloody hope so.. I'm pissed about trading my rm for it so far... :) but i will say it much easyer to ride then the rm..
  • Indy_WR450
Posted February 13, 2005 - 05:39 AM
You really need a YZ450 exhaust cam to make it rev quicker! :)
  • Gadsen
Posted February 13, 2005 - 08:06 AM
Indy, do you have the YZ exhaust cam in yours? I have one (OE Yamaha) and considering the swap. Problem is, I trail ride and like the low speed trail riding. What was the changes from the stock to the YZ cam. I had a WR426F with the YZ timing and it hit hard, but low speed trail riding did suffer. But I was able to work around it. I guess I'm trying to decide if I should do it. Not trying to hijack this thread. :)
  • ncmountainman
Posted February 13, 2005 - 08:25 AM
the wr makes its peak power @ 7500-8500 rpms depending on your setup, its not gonna rev and continue to make power like a 125 two stroke! i let people ride my bike that have two smokes and i almost cry the way they bounce off the rev limiter. (i don't let those people ride anymore) dang two smokers :) but anyway you just need to ride a little differently,pay attention to where the power comes on and use the bottom end to your advantage,short shift and let the motor work. you will have improved traction and the bike is way easier to ride fast when its not all wound up. you can lug around and then scream it when you have to down the stretches and not even have to leave 3rd gear! :) the yz cam will move the HP peak to a higher rpm but at significant loss to your truck like bottom end.
  • elton
Posted February 13, 2005 - 10:43 AM
Did you do the throttle-stop mod? I have to remind myself to use the extra throttle gained from the mod; when use all of the throttle, even at high speeds, "all hell breaks loose" as the revs keep building. The WR ether sprays a rooster tail of mud/dirt or becomes a unicycle -- an amazing high speed, high rev hit.
I've done the four primary mods; not touched the jetting yet as the bike runs perfectly -- but I have the JD kit as well as the Lowedog kit (will do both soon).
Elton
  • new2fourstrokes
Posted February 13, 2005 - 04:00 PM
i have done all the mods... i might just be me, like i said i've never owened a 4 stroke ony 2 strokes...
  • Indy_WR450
Posted February 13, 2005 - 04:53 PM
I ran the YZ450 cam for about a month and went back to the WR cam and sold it to TT member NHKevin. I could not handle the midrange hit in the woods. It was too much for my riding style. I really have addapted to the WR powerband and I recommend it for eastern riding. Out west I would consider running the YZ450 cam for open high speed riding. :)
  • Gadsen
Posted February 13, 2005 - 05:47 PM
I ran the YZ450 cam for about a month and went back to the WR cam and sold it to TT member NHKevin. I could not handle the midrange hit in the woods. It was too much for my riding style. I really have addapted to the WR powerband and I recommend it for eastern riding. Out west I would consider running the YZ450 cam for open high speed riding. :p
Thanks, I'll stick with the stock cam and sell the YZ one. Anyone want a YZ exhaust camshaft for a 450? :) :)
  • Indy_WR450
Posted February 13, 2005 - 05:59 PM
The guy who started this post needs one! TT member "New2fourstrokes" needs that arm stretching faster reving gorrilla power! :)
  • new2fourstrokes
Posted February 13, 2005 - 07:33 PM
well guys and girls i'll see what power these wr450s have booked in for a dyno run...
  • new2fourstrokes
Posted February 14, 2005 - 05:05 PM
OK OK first run it was 46hp thats with all mods done sept Grey wire.. JD jet kit red pin 3rd clip 168 main.. now we took the side cover off the one where the cut out holes are jumped straight to 49hp.. now that not bad.. :)
  • Indy_WR450
Posted February 14, 2005 - 05:31 PM
You will get 4 more HP with the YZ450 exhaust cam. :) Why not make Toyota_MDT_Tech an offer. :)
  • new2fourstrokes
Posted February 14, 2005 - 05:42 PM
let me ponder this thought for awhile indy :)
