WR426 SuperMoto bits - - Advice needed
2 replies to this topic
  • WR Riffton
Posted February 11, 2005 - 05:44 PM
Can someone tell me if all the main parts needed to SM my 426 are pretty much the same from '99 models onwards?? The same goes for 400/450 and YZ stuff too.
I keep coming across stuff on Ebay, such as 320mm front discs, caliper brackets, chains, wheels etc, for models across the board, but I'm uncertain as to whether the YZ/WR 400/426/450 models and years are all cool to use the same stuff on???
The main reason I ask is that I've had problems with my '02 WR426F. I ordered a DEP Enduro Pipe for it, but it didn\'t fit (bracket was a couple of Centimetre's out). Both myself and the dealer assumed it was a fault and a one-off. I then asked for another one (but a YZ pipe instead as the WR pipe didn't really have as much power/noise as I wanted) and it had exactly the same problem!!!! :)
We concluded that because my WR is such a late model (reg'd 04, and they stopped producing them in late '02) it may have a WR450 frame. Either way the frame spec seems different than a regular '02 WR.
With this in mind, I figure that I just might have all sorts of probs if the parts that I need have not been manufactured to fit all WR/YZ's (depending on which bids I win!!) The wheels aren't really an issue as I'm having these rebuilt - but obviously my frame is different. Are such things as brakes spindles, bar clamps, chain lengths etc etc homologous on all models? :)
Any advice would be well appreciated as I really want to get moving on the conversion pretty soon!!
Cheers,
Riffton.
  • Chris_from_Oz
Posted February 11, 2005 - 06:48 PM
I don't think your 426 would have a 450 frame. It's more likely that the exhausts they've sold you have been for a 450. Only other thing is, did you buy it new? If not, a previous owner may have fitted 450 subframe, airbox, sidepanels, seat, tank etc, in which case a 426 exhaust bracket would prob'ly be out by a couple of cms? Unlikely that is the case, but I can't think of another reason why 2 exhausts wouldn't fit a 426. Unless they're to suit a 450 of course.....Let us know what you discover. :)
  • ddold
Posted February 11, 2005 - 06:59 PM
When I sold the SM stuff off my '00 WR, it was swapped straight on to a '02 WR and fit fine. I'm running his stock wheels and braking setup, including caliper and master cylinder.
Dave
