YZ Rear Fender on 05WR450?
15 replies to this topic
  • motodude42
Posted February 11, 2005 - 09:20 AM
I would like to replace the rear fender with a YZs. Anyone done this yet or know if it will bolt right on? :cry:
  • dustdogg
Posted February 11, 2005 - 09:32 AM
It should, all of the previous years did. Some did require minor trimming from what I have heard, although the YZ fender on my WR bolted right up :cry: Give it a try it will look great :cry:
  • The_Blue_One
Posted February 11, 2005 - 09:45 AM
Acerbis made a yz style replacement for the 03 wr's. I don't know if it will fit but you could check yamaha's part number for the 03 and 05 fender and see if they're the same.
  • RADRick
Posted February 11, 2005 - 11:04 AM
I used an Acerbis YZ replacement on my '04 WR and it worked perfectly.
  • Texas4play
Posted February 11, 2005 - 03:06 PM
I used the Yamaha o.e.m. YZ fender on my '05 WR. Requires trimming for the left side subframe overflow tank mounts however, rumor has it that some of the aftermarket fenders are pre-cut.
  • ncmountainman
Posted February 11, 2005 - 03:31 PM
the UFO yz replacements come with the holes molded in ready to cut out. :cry:
  • motodude42
Posted February 11, 2005 - 04:02 PM
Cool, Thanks guys. I appreciate it. :)
  • patrickincc
Posted February 11, 2005 - 04:28 PM
Yes it will work. I did mine. You will have to cut out a bit but there marked to do this.
  • simica
Posted February 11, 2005 - 10:02 PM
Yes it works. Both Acerbis and GYT-R make identical fenders that are premarked for cutting out the area by the overflow tank. Use a Dremel tool and it will come out sweet. I also went to a autoparts store and got some of that silver exhaust thermal tape to put on the area near the exhaust pipe. Just duplicate the stock WR fender, the tape works really well and has not come off after half a dozen rides and washes.
I have also installed a YZ front number plate for racing purposes. This required some homemade bracket fabrication and relocating the ignition switch. If anyone would like to see pictures, I'll have to figure out how to attach the pics to a thread.
  • Dunlop
Posted February 12, 2005 - 07:08 PM
Hey Simica, I am going to put a YZF number plate on my bike and would like to hear how it went for you. If you could get those pictures up that would be cool because I have no idea where to start.
  • tammie
Posted February 13, 2005 - 07:34 AM
hey guys, im looking for a WR rear fender for my 99 YZ ....withthe light.........anyone whose taken theirs off want to sell it........??
pm me.....
  • motodude42
Posted February 13, 2005 - 07:49 AM
My next step is to take the headlight off and install a standard YZ number plate. Peeking behind my headlight, looks like a lot of wires for a headlight and ignition switch. Did you remove all the wires when you did this or leave them in place? :)
  • NoControl27
Posted February 14, 2005 - 05:56 PM
It does work. I just did this on my 04 WR450. I had to trim the both side slightly but everything worked well. Now I want to put the YZ 450F front plate on it. This may be a bit more challenging.
  • Tab812
Posted February 14, 2005 - 06:02 PM
It will work....Just did mine
  • SteveWR450F
Posted March 23, 2005 - 10:28 AM
I have been reading your threads about putting YZ plastic on WR to save weight. I have a 04 WR450F and have been thinking the same to save weight. Any advice or pictures you can offer would be greatly appreciated. Thanks for your time,
Steve
SteveWR450F
  • ncmountainman
Posted March 23, 2005 - 11:40 AM
you can do like i did,take out the headlight assmly and attach a piece of HD dog proof window screen across the inside of it (i used liquid nails and a couple sheet metal screws) it gets more airflow over the radiators and the screen keeps out the junk. and it costs about nothing,and you can put the headlight back in easily if your gonna need it. :)
