How much fork oil, '05 YZ450F
4 replies to this topic
  • timvan
Posted February 08, 2005 - 10:11 AM
Im doing a spring swap on my 450, dumping out the old oil and adding new. :cry:
How much oil to add? Im assuming this measurement is with the fork collapsed and measured down to the oil line?
Thank You!!
Tim
  • timvan
Posted February 08, 2005 - 02:54 PM
ANYONE? :cry:
  • Matt96xr6
Posted February 08, 2005 - 07:13 PM
You did not get a manual with your bike?
For the inner chamber, you fill up to above the taper, than install the top compression assembly, pump the forks 10 times and bleed off the excess fluid. Usually around 190-220 cc.
The outer chamber (which may be as far as you are going with just a spring swap) takes 245cc. Add about 5-10cc more to help bottoming resistances. Spec is 200-300cc
  • ACE_269
Posted December 25, 2005 - 09:23 PM
Does anyone have a measurement for this procedure? I am planning on just inverting the forks and dumping out the old oil and replacing w/ new.
  • Matt96xr6
Posted December 25, 2005 - 10:37 PM
Look with the twinchambers, you cannot just dump in fluid and measure.
  • Hot  36 replies
  • Hot  38 replies
  • 10 replies
  • Hot  28 replies
