Front Sprocket Guard
5 replies to this topic
  • dangermouse007
Posted February 08, 2005 - 08:11 AM
Do you guys have both Front Sprocket guards on or just the Metal one.. reason I ask it all the mud/grass and stuff.....just gets stuck behing it and me mate on his CR only has the Metal one on ?????
  • 5valve
Posted February 08, 2005 - 08:15 AM
I removed both and replaced with home made alu 0,3in thick guard that already withstood two chain breaks with no colatheral damage
  • dangermouse007
Posted February 11, 2005 - 03:31 PM
Bounce
  • ncmountainman
Posted February 11, 2005 - 03:36 PM
ya, the chain is way happier without the plastic part. i've been running it with just the aluminum part and probly need to go with a heavier gauge or i was thinkin' maybe stack two together. anyone have an extra layin'round? :cry:
  • Chris_from_Oz
Posted February 11, 2005 - 06:38 PM
I just run the aluminium part, it polishes up nicely too for added 'bling' :) If you just use the alloy bit, be sure that the bolts don't bottom out in their holes. I seem to recall having to use different bolts on my 426.
  • dustdogg
Posted February 11, 2005 - 07:10 PM
I recently ditched my plastic guard too. I kept the aluminum "case saver" behind it. Watch the stock bolts, mine bottomed out before it tightened up. I found some allen head bolts (metric) at Lowes that worked perfectly :)
