SRC d/s BRP brake light 'simulator'..
6 replies to this topic
  • thumpasaurus
Posted February 05, 2005 - 04:37 PM
src brake light
I called it a simulator, becuase it turns your single filament O.E. running light into a brake light by running through a resistor until you step on the brake when it lets full current to the light. It uses one of those banjo bolt switches..
I bought one of these things and it installed in about 5 minutes and actually works pretty good. It takes longer to remove and replace the plastic and tail lens cover than installing the device. I tried both a 158 bulb (stock) and a 198, and IMO the 198 seems a little brighter.
It's still a wimpy amount of light, but it does work, is ridiculously easy to install, and only cost $38.. bringing me that much closer to an actual inspection sticker.. :cry:
  • Winkel
Posted February 05, 2005 - 07:12 PM
I did that on a Yamaha MX175 I had when I was sixteen. It actually worked to make that bike street legal. That was my first 'dualsport' bike twenty-four years ago.
  • Winkel
Posted February 05, 2005 - 07:15 PM
Also, for the cost of the banjo bolt switch ($16), and a small LED light from Autozone, you could just add an auxilliary brake light. That's what I did for my R to make it street legal.
  • thumpasaurus
Posted February 05, 2005 - 07:43 PM
Sure, I know there are other options, and probably better and brighter ones at that. The beauty of the SRC thing thing is simplicity. It comes in one little package, no wiring, no cutting, crimping, nothing but a 12mm socket to change the banjo, plug it in, a couple zip tie, a few minutes and your done. Rolling your own might save you $12 or so, assuming you already have crimpers, ends, wire, soldering iron, etc at your disposal. Still not accounting for your time.
RE: LED lighting, fill me in here I'm not an electronical guy. Does the brp have a rectifier? I thought not, that it had only a regulator and the lights ran off AC. Thinking that, I figured that an LED wouldn't work since it requires DC. Am I wrong about some/all of this, or did you add a rectifier.
  • jws
Posted February 05, 2005 - 09:13 PM
src brake light
this is the same thing i use :cry: - sure you could make it cheaper but i perfer the plug and play way also :cry:
  • Winkel
Posted February 05, 2005 - 09:44 PM
Thumpasaurus,
The LEDs run fine on our setup. I understand your appreciation for the plug and play, but in my opinion the LEDs are safer because they are pretty bright. I'm kind of concerned about some old lady plowing into my caboose at a stop sign because she doesn't see me. I made my own, and it is working well so far. I'll try and post a link. I think it's kind of trick, and I can remove the whole thing really easy. (for full off-road) Just my two cents.
http://img.photobuck...el/IMAG0098.jpg
Winkel
  • thumpasaurus
Posted February 06, 2005 - 01:03 PM
Hey Winkel, very cool. :cry:
I might add an LED later too.
  • 2 replies
  • 17 replies
  • 7 replies
Washington
  • Hot  32 replies
Honda XR650L 2017
  • 0 reviews
