DP'ing a WR...electrical system OK?
6 replies to this topic
  • vrecksler
Posted February 05, 2005 - 04:10 PM
The old TT format had a very thorough listing of all free mods and loads of information for the WR's, and if it is still around please post a link and I will go there.
Anyway, I want to plate a WR 450 and know very little about its wiring. Can the existing harness and stator support a DOT light (with low and high beams), as well as turn signals? My last DP (dual purpose) was a DRZ S so it had everything I needed but lacked performance. I am in unchartered territory here so I thought I would post up. :cry:
Thanks!
  • bdmmotard
Posted February 19, 2005 - 12:29 PM
i'm looking for the same information but for a wr400, if anyone could point me in the direction of some diagrams/instructions. looking to wire up turn signals using stock electrical system. thanks!
  • Fryboy
Posted February 19, 2005 - 12:46 PM
Hey Guys,
I suggest speaking with Dale at Trick Dual Sports. He will answer all of your questions.
You will at the very least need a new harness. The stock one will work but will need modifications to do so. The stocker can support headlight, tail light, but not the blinkers, brake switch, turn signals, high/low beam or horn.
I ride WR426 and can tell you without a doubt, the stator is more than powerful enough to run my kit.
See Trickdualsport here:
http://trickdualsport.com/aboutus.html
Ask for Dale :)
Fryboy
  • Indy_WR450
Posted February 19, 2005 - 01:24 PM
Ditto! Go with the Trick Dual Sport! :) It is a first class design with all you need in a very well engineered package! Don't even consider other brands they either get it wrong ( Baja Designs) or are inferior! :)
  • GasAHolic
Posted February 19, 2005 - 02:21 PM
The old TT format had a very thorough listing of all free mods and loads of information for the WR's, and if it is still around please post a link and I will go there. Thanks!
These may be what you're after:
http://www.thumperfaq.com/sitemap.htm
http://www.thumperta...ighlight=sticky
Good luck :)
  • doctorchopper
Posted February 19, 2005 - 03:38 PM
You won't have any trouble at all with your 450, it will be even better than my 426 as your 450 has a battery which acts as a big capacitor. my light goeas dim at idle, but comes to life with any sort of rpm, baja designs has a quick release kit for the 450, not sure what its like, but its out there.
  • Indy_WR450
Posted February 19, 2005 - 04:13 PM
:) :p :D :D ;) :D :lol: :D :D :D :thumbsup: :thumbsup: :cry:
I dont know why people insist on recommending Baja Designs after all the documented horror stories all over TT. :)
It is quick release so you can toss it in the trash! :o
Trick dual sport can be installed permanently or can be removed and turned back into stock set up in about 15 minutes. :lame:
