Uneven brake pad wear
6 replies to this topic
  • buck_y_lee
Posted February 03, 2005 - 03:47 PM
The outer rear brake pad on my 2000 yz426 is almost gone, but the inner is almost at full thickness.
Anyone else experiencing this uneven wear?
  • bushy
Posted February 03, 2005 - 04:34 PM
I am.
  • buck_y_lee
Posted February 03, 2005 - 04:37 PM
Think I may swap the pads around, rather than buy a new set. Whadayareckon?
  • bushy
Posted February 03, 2005 - 04:39 PM
You cant swap them around, they only go in one way.
  • CRFThumper
Posted February 03, 2005 - 04:40 PM
Thats a great idea!!!!Let me know how it works out, :cry:
Posted February 03, 2005 - 04:57 PM
Check the caliper pins. The caliper has one "hot", or "live", or driven pad, and one "cold", "dead", or fixed pad. In order for both pads to bear against the rotor with the same pressure, the caliper needs to be able to slide fairly freely on the mounting pins. If they're dirty or binding, the result is uneven wear. A certain inequality is going to be unavoidable, but they shouldn't be radically different.
Push the driven pad back into the caliper with a screwdriver (carefully) and see how well the caliper slides. Pump the pedal/lever gently a few times to puush the piiston back out whenyou're done checking.
  • buck_y_lee
Posted February 03, 2005 - 05:21 PM
Good point!
Thanks grayracer. I'll try that.
  • 5 replies
  • On January 15, 2017
  • 10 replies
  • Hot  50 replies
