??? from another FNG
9 replies to this topic
  • MortgageRider
Posted February 03, 2005 - 01:14 PM
First off wanted to start by saying hi to you all and what a great board with a wealth of info here.
Question is jetting on an 05 all the free mods done YZ pipe and Lowedog kit soon on the way. Riding 90% of the time at sea level (Ocotillo Wells). It has the usual decel popping and slight backfire.
I know there are many treads on here about jetting but there are so many different setups and combinations being used I don't know the right one for me.
Thanks in advance for the help.
:cry:
  • purluvwr450
Posted February 03, 2005 - 01:20 PM
cut the ais tube going from the pump to the head in half then get a two sided nut to fit tight in the hole then close and ziptie both ends, popping and backfire will be gone I swear
  • MortgageRider
Posted February 03, 2005 - 01:24 PM
The lowedog kit is to eliminate the A.I.S. system with plugs. It is a very clean kit.
I also must add that the head pipe gets to be [COLOR=Red]glowing red[/COLOR] :cry:
  • purluvwr450
Posted February 03, 2005 - 01:32 PM
glowing normal, I was saying that the popping and decel are from the ais not jetting, if you want to fix before you get the kit do what I said
  • MortgageRider
Posted February 03, 2005 - 01:36 PM
The glowing is not from a very lean condition?
  • purluvwr450
Posted February 03, 2005 - 03:40 PM
even after the jetting if your in the dark that thing will light the sky!
  • MortgageRider
Posted February 03, 2005 - 04:15 PM
Are you suggesting not to do any jetting? or which setup should I run?
Most I see look like 170 main 48 pilot 70 starter. This sound good?
  • purluvwr450
Posted February 03, 2005 - 05:46 PM
I'm not nearly that good just sharing my experiences with you, as for my self, I went for the JD kit and followed the suggestions for my area. :cry:
  • jasilva
Posted February 03, 2005 - 07:45 PM
That should be the correct jetting for you. Also get an 04 needle and try the 4th position from the top.(05 needle is non-adjustable) Also get a zip-ty racing fuel mixture screw. With the 48 pilot you'll have to adjust the idle mixture leaner as the weather warms up.
Joe
  • MortgageRider
Posted February 04, 2005 - 10:09 AM
There are 5 different part numbers for an 04 needle. Do I just use the STD one?
